DIY Stompboxes => Building your own stompbox => Topic started by: tuckster on September 26, 2023, 02:21:18 PM
Title: semi parametric eq - noise
Post by: tuckster on September 26, 2023, 02:21:18 PM
Hello lovers of the new forum design,
I recently built a nice pedal from GCI and I have a nasty noise on the high control of the semi parametric eq part of this "pedal" (in terms of monster pedal).
https://kurtballou.com/docs/N.E.W.%20TTTSNB%20EQ%20PCB%20Build%20guide.pdf
Turning the high controll to ccw to min gives a nasty noise. The noise is noticable from 0 to like 3 (10 o'clock).
(https://i.postimg.cc/XXRr6mtF/noise.png) (https://postimg.cc/XXRr6mtF)
On pin 2 & 3 of IC8A everything is fine. Is there something I can check/swap/tinker?
Title: Re: semi parametric eq - noise
Post by: antonis on September 26, 2023, 02:45:00 PM
Tyy to place a resistor (of trial & error value) between lug 1 and IC8A output.. :icon_wink:
