Hi! I'd built this tonigth and i'm very impressed... :o I'm still a newbie but..
it sounds :shock: .....and it sounds very good to my ears! I don't have any j201 by the moment but i i have a bunch of mpf102's and 2n5457's that will make the job ok i think...at least untill i get some j201's.
The circuit is the crunch channel of the carvin legacy tube amp (yes, Steve Vai's own) and i'd copied it part by part using 2n5457's instead the 12ax7 tubes and like meteor and the runoffgroove's emulations i'd adedd two simple rc filters at the end as an intend of emulate the response of the speakers...
The sound; well i don't know how can sound a carvin legacy amp in the reality :oops: the demo at the carvin's site is not ONLY the amp...and i don't have one of this to compare...sorry! :oops:
The sound is very impressive for me, now is too late (3:00) and i can't turn the volume knob enough to make a "serious" review of it, but it sounds very fine at low volume! the tone control is a 3 knobs baxandall type (i think) and it seems to works very fine...i think it sounds bluesy :roll:sorry but now is dificult for me to explain this.... tomorrow i'll record some clips and i'll post them for you!
Thanks to Doug Hammond and the guys at Runoffgroove for your work and for share it! and thanks Marcelo for the schematic file!
Which amp would that be? I Have a Musician's Tube model VTR2800 100W , 2 channel, 7-band graphic EQ, spring reverb, and full/half power switch through an old Acoustic 6X10" cabinet. Mostly use the clean channel overdriven with an EPFM preamp or a PAIA AxeGrinder boost. (Could never use the full power...too LOUD!) Would be interested in sound clips when availiable.
Congrats on your build :D
Aguante maestro! :D
I'll be waiting for those clips.
Buenisimo!!!!!!!!!!!!!!
Cool!!!!!!!!!!!!!!
Mi pedido se hizo realidad, pasame el circuito o subilo en algun site asi lo veo y lo armo.
My dreams come true!!! try to post the schem to build it, might be cool that Mr. ROG and/or Doug compare it to the original schem and maybe take it closer if you leave something to improve.
Congratulations and of course, we are waiting that samples.
Saludos, Marcelo.
Congratulations, Lucas! Very well done! I look forward to soundclips.
Quote from: Tony ForestiereWhich amp would that be? I Have a Musician's Tube model VTR2800 100W , 2 channel, 7-band graphic EQ, spring reverb, and full/half power switch through an old Acoustic 6X10" cabinet. Mostly use the clean channel overdriven with an EPFM preamp or a PAIA AxeGrinder boost. (Could never use the full power...too LOUD!) Would be interested in sound clips when availiable.
I HAVE THE SAME AMP! Cool! I used to have two, but traded one for a Squire JV Strat. In fact, I have only seen two, and both were mine!
I have the owners manual saved to a pdf file if you want it.
please post sound clips sometime... im keen to hear this thing!
:D Thanks to all!
I'm working on those samples, i hope i'll can make a few takes tomorrow and post them...
I have an schematic file too, actually i'm working with Gringo to make it more "decent" and maybe a layout and pcb files will be available in the next days...
Again sorry for my poor english... :oops:
Regards
Lucas, check your mail ;)
Congratulations! That's very cool! 8) 8) 8)
I look forward to hearing it!
Take care,
-Peter
PS: Your English is just fine, I can understand you perfectly. :D
Now you've got the idea. :D :D
You can apply this technique to a lot of different amps.
Congratulations! Look forward to hearing the clips. :D
Doug
Definitely want to hear the audio clips. Where can I get a hold of the Carvin Legacy schematic?
Alf
QuoteThe circuit is the crunch channel of the carvin legacy tube amp (yes, Steve Vai's own) and i'd copied it part by part using 2n5457's instead the 12ax7 tubes and like meteor and the runoffgroove's emulations i'd adedd two simple rc filters at the end as an intend of emulate the response of the speakers...
If used as an fx pedal, why simulate speakers?? or is this to compensate for more highs when using fets?
Well...I have a BAD sample of the "Leegazzy" :wink:
But i can't upload it because i'm not able to access the site when i'd uploaded all my mp3's in the past (http://www.hispasonic.com/)...sorry! Maybe tomorrow i'll can do it.... :roll: I hope...
Quote from: DutchieIf used as an fx pedal, why simulate speakers?? or is this to compensate for more highs when using fets?"
If you want emulate the sound of an amp, you'll want emulate the speakers response of that amp too, since the speakers are a important piece in the result sound i think...althoug you are going to use other guitar speakers when use this the overall sound is more similar IMHO but is only MY OPINION! :wink: Maybe i'm not the most capacited to tell you this! :roll:
Quote from: ahermidaDefinitely want to hear the audio clips. Where can I get a hold of the Carvin Legacy schematic?
Get me your mail and i'll send you a copy!!
The VL100 & VL212 series i think...
P.S Good news! In the next days a pcb express file and a eschematic will be available courtesy of our friend Gringo!
Again thanks to all!
Love to see the scematic too!!
saw Steve the other day ( yes, vai ) the other day...got a nice masterclass. he brought 2 amps, i think it where legacy 212's for stereo fx
he used a ts-9 as a booster in front of it and a g-major for delay and what not....i must say i wasnt really impressed with the sound of his setup, but that's a matter of taste, isnt it.
nice technique though. real freak hehe
Quote from: DutchieLove to see the scematic too!!
:shock: Mmmmmmm.....a masterclass? wow! i want one of this!!! :lol:
not really impressed with the sound? but similar to his records?
Grigo has made a great job with the pcb and the schematic file...you can find this on his web, here are the links:
http://gr1ng0.tripod.com/Leegazzy/Calvin_Layupe.jpg
http://gr1ng0.tripod.com/Leegazzy/carvin_v1.1.sch
http://gr1ng0.tripod.com/Leegazzy/carvin_v2.pcb
Regards
Well, i added a link to all the files at the downloads page of my site, just in case.
http://gr1ng0.tripod.com/Downloads/dl.html
I have a previous version of the layout that was too big, about 10cmx 3cm (4" x 1.2"), the "release" one being 7cm x 3.5cm. It's a little less tight as a consequence, so if anyone asks, i'll mail it.
Have fun!
I still believe "sound" and "tone" comes from the fingers.
great amps and fx of course help to get what you want, but you're personality is in your fingers, what i'm trying to say is the "vai sound" cant be made with the same setup.
no matter what i play..i always sound as me...thank god i do..hehe
Quote from: DutchieI still believe "sound" and "tone" comes from the fingers.
i do agree but i do belive that someone can get very beliveable close to the sound if you learn to copy the nuances of your favorite player..
yes sure, but do you want to???
As guitar playing is my "work" i try to be "me" all the time, i dont say thats so special but it's nice when ppl hear a recording or what not and can hear its me.
Now i got my degree in music, i'm trying to find again the entusiasm i had when i was 15. i got a mind full of theory, technique, what can and cant be done....aaaaarrghh the conservatory got to me.... i got no hero's any more...for instance..even Vai is just another guitar player to me..nice dude..but nothing special.....
hmmm sorry for this of topic blabla
Quote from: Dutchiei got no hero's any more...for instance..even Vai is just another guitar player to me..nice dude..but nothing special.....
haaaaaaaa thats too true man.
i feel what you are saying. i was accepted at GIT Eleven years ago in my junior year of highschool but parents would let me go and layout of school a year.
i am going to say one final thing and not hijack threads or participating in thread hijacking anymore :D
i think when you first start out its good to find someone to emulate to some degree as it will help you develop faster when you acomplish something that you want to learn vs. just learning the scales cause it will make you a better player, you can tell someone that all day long, but if you say if you want to sound like artist blah you need to be comfortable with these techniques first. and give examples it makes for a better student with quicker result..
shoot i dont' like country music man but by teaching Kids how to play it they were happy and went home and learned their lessons.
Now When things settle down i am going back to teaching Intermediate Shred and Theory.
for the record My Third Magor was Music also
Hi there,
i am interested in building this Legacy JFET emulator. But the PCB file doesn't open in ExpressPCB 6.1.4.
The sch file opens correctly.
Do you also have a perfboard layout ? (or a jfet emulator general layout, to adapt for this particular build ?)
Thanx in advance, have a nice time
I've begun to breadboard this project (even if i don't have all the exact parts needed, just maded a big order).. So, using parts that have similar values, and using 100k trims instead of 47k ones, and having only the first three stages breadboarded, i must say that it begins to sound good !
Is using 47k trimpots necessary ? Or could i use te 100k ones ? And in this latter case, should the biasing voltage be alwasy 4.5V ?
Thanks in advance
you do realize the post you replied to is over 5 years old?
Good luck anyway!
Oh sure Auke, now that you've told me, yes !!
Excuse me, i'm new to this hobbie, and all informations, even the old ones, are crucial.
Have a nice time, bye
Quote from: demym on August 19, 2009, 02:02:57 PM
(...)and all informations, even the old ones, are crucial.
Very true.
I'm just pointing out that you could have better chances getting a reply by starting a new thread (as you did, I think).
It's a great hobby, keep it up!
Bump from the grave.
The pcb files linked to in this thread are all invalid. Does anyone have working pcb files?
Thanks.
Tim
Quote from: Zilla on October 26, 2013, 11:30:16 AM
Thanks.
Tim
I don't have the one in the original post but I have this one made by Seemann Customs from the same schematic. I have built it using this layout and it works..
Demo
https://www.youtube.com/watch?v=5H9beG25jPY
Transfer
https://dl.dropboxusercontent.com/u/11178619/Carvin/Carvin%20Legacy.pdf
(https://dl.dropboxusercontent.com/u/11178619/Carvin/Leegazzy%20-%20small.jpg)
(https://dl.dropboxusercontent.com/u/11178619/Carvin/DSCN4187.JPG)
(https://dl.dropboxusercontent.com/u/11178619/Carvin/DSCN4189.JPG)
would you happen to have the info on where the power connections, in, out, and board-to-board wiring goes?
