DIY Stompboxes => Building your own stompbox => Topic started by: markusw on June 30, 2004, 04:35:01 AM
Title: Stupid Q: R and C values for a Schmitt trigger oscillator
Post by: markusw on June 30, 2004, 04:35:01 AM
How do you calculate the R and C values to run a CD40106 at a given frequency (like in R.G.s sequencer)? I have looked through the data sheets but I can´t figure out how to do it. Thanks for your help.
Markus
Post by: bobbletrox on June 30, 2004, 05:46:01 AM
The formula can be found on this site:
http://www.interq.or.jp/japan/se-inoue/e_ckt13.htm
(I have no idea how to do it though!)
Is it just me, or has the forum got sequencer fever?  :D
Post by: maximee on June 30, 2004, 06:18:30 AM
no bobbletrox...i have the same feeling....and i think that we two kind of started it :)
Post by: Arno van der Heijden on June 30, 2004, 06:21:39 AM
Also, look here:
http://www.electronics-forum.net/design/how_to_det_freq_of_schmitt_oscillator_326334.html
Post by: Arno van der Heijden on June 30, 2004, 06:36:12 AM
And here:
http://www.ece.concordia.ca/~a_mozgov/main.php?pg_num=42
Post by: markusw on June 30, 2004, 07:40:38 AM
Thanks a lot! After browsing through all these links the f=1/RC formula seems to be a sufficient approximation. When using the larger formula containing the + and - treshh. voltages, f values change quite a bit depending on whether you use  the min, max or typ values (e.g using the typical values for CD40106 at 10V VDD the formula looks like f=1/RC*1,5) So, if I got it right, the exact f can´t be predicted since it depends on the exact properties of the chip in your circuit.
BTW: boobletrox, if I did the calculation correct you needed to go down with R4 in your http://users.bigpond.net.au/styrowfoam/eightstep.gif schemo to 4,7k in order to reach 10 Hz (maybe even lower when using the larger formula). Please correct me if I am wrong.
Indeed, there seems to be some kind of sequencer flu. I got caught by the "my Meatball needs a 4,6,8 step up/down/random" virus. So RG´s sequencer seems to be really fine. However, at the moment I can´t figure out how to switch to 6 steps.
Take care,
Markus
Post by: bobbletrox on June 30, 2004, 08:49:18 AM
Quote from: markuswBTW: boobletrox, if I did the calculation correct you needed to go down with R4 in your http://users.bigpond.net.au/styrowfoam/eightstep.gif schemo to 4,7k in order to reach 10 Hz (maybe even lower when using the larger formula). Please correct me if I am wrong
I used the values from Tim Escobedo's Ez-Lfo because I figured any Lfo with a decent range should work fine for controlling the tempo of a sequence.  But 4.7k gets it running within RG's specs does it?  Thanks!  I'll try that out.
Post by: markusw on July 01, 2004, 02:29:03 AM
In the Ez-LFO there is a 2.2 µF cap. So the frequency goes up to about 10Hz.
