DIY Stompboxes => Building your own stompbox => Topic started by: skiraly017 on October 26, 2005, 12:56:51 PM
Title: Did someone post a link to a simple A/B/Y box a little while ago?
Post by: skiraly017 on October 26, 2005, 12:56:51 PM
I thought I saw it here, but I could be wrong. I thought I saved it, but I can't find it. For all the thinking I'm doing, I'm not getting very far.  ???
Title: Re: Did someone post a link to a simple A/B/Y box a little while ago?
Post by: Strat Cat on October 26, 2005, 01:36:45 PM
Here's a diagram for an A/B or A/B/Y box...
(http://pic5.picturetrail.com/VOL83/511092/1450949/65546358.jpg)
Post by: TheBigMan on October 26, 2005, 05:59:35 PM
This one?  It's in my layouts gallery.
(http://aronnelson.com/gallery/albums/TheBigMan-Layouts/abyled.jpg)
Post by: Strat Cat on October 26, 2005, 06:38:10 PM
The second one seems to be a waste of money since it uses 3PDT switches when the top one only requires DPDT switches.
Title: Thanks for the diagrams, but it wasn't either one of those.
Post by: skiraly017 on October 26, 2005, 06:52:01 PM
"I think" it was a link to a parts supplier who had an A/B/Y diagram as well as Fulltone's A/B diagram in his site. I should have made sure I bookmarked it. Doh!
Post by: dosmun on October 26, 2005, 09:17:06 PM
QuoteThe second one seems to be a waste of money since it uses 3PDT switches when the top one only requires DPDT switches.
These days the 3PDT are cheaper than the DPDT's.
Post by: Strat Cat on October 26, 2005, 09:32:27 PM
Quote from: dosmun on October 26, 2005, 09:17:06 PM
I get my DPDT switches for $2 and change. All the 3PDT's I've seen are about double that.
Post by: dosmun on October 26, 2005, 10:50:03 PM
QuoteI get my DPDT switches for $2 and change. All the 3PDT's I've seen are about double that.
Where do yo get them?
Post by: Strat Cat on October 26, 2005, 10:55:03 PM
MCM Electronics
Post by: Dragonfly on October 30, 2005, 04:01:30 PM
Quote from: skiraly017 on October 26, 2005, 12:56:51 PM
This isn't an A/B/Y box, but just in case someone is looking for an easy to build A/B box....
http://aronnelson.com/gallery/album20/PASSIVE_A_B_BOX_LAYOUT (http://aronnelson.com/gallery/album20/PASSIVE_A_B_BOX_LAYOUT)
Post by: TheBigMan on October 30, 2005, 05:12:56 PM
Quote from: Strat Cat on October 26, 2005, 06:38:10 PM
Mine is a redraw including LEDs of a schem often posted by Andi.  It grounds the unused channel for low noise, which one with DPDTs does not do.  If you are using this for switching between two amps it is essential to ground the unused amp input.  Just think of the noise you get from having a guitar cable wafting in the air.
Post by: The Tone God on October 30, 2005, 07:02:09 PM
What you need depends on what you are doing. Do you only need A/B and no Y ? What signals are you switching ? You may need an active A/B/Y. You may need isolated outputs.
There is a lack of information as to what the OP needs are so a recommendation is hard to make. Its all guess work at this point.
Andrew
