Hi everybody!
I'm finally putting this baby together. I have a few questions before I go ahead.
Could the 1 Uf cap in the feedback path be set in series with a pot or something to make a tone knob? Or is this a little more complex?
You *could* modify some of the filtering stages already there to be variable... Probably a better idea would be to add a simpler one where desired.
Search the forum for 'low pass filter' or something along those lines.
Quote from: Fp-www.Tonepad.com on March 06, 2006, 03:49:00 AM
It sounds like to much of a hazzle right now.
Will decreasing that cap make the repeats more trebly?
Depends. As I said, you can research on filtering stages and feel free to change whatever part you desire. The design is quite forgiving in that sense, so just add a few sockets here and there and try different values.
