DIY Stompboxes => Building your own stompbox => Topic started by: mac on May 23, 2006, 12:26:20 AM
Title: Scaling RG germanium test.
Post by: mac on May 23, 2006, 12:26:20 AM
In my previous post,
http://www.diystompboxes.com/smfforum/index.php?topic=45433.0
I mention that some 2N388 I have increase their gain by a factor of 1.7 - 1.9 if the base current ib is ten times the standard 4uA RG germanium test uses Note that 4uA is the base current of a magic fuzz face, so RG test gives you the values of your germaniums oparating in a fuzz face. Nice.
But some transistors have more, or less, juice at higher base currents, that is, hfe is a function of the collector current ic, hfe = hfe(ic).
Ok. Most of us use the test almost exclusively for our fuzz faces. But there are other projects, like a class A, A/B amps with higher base, and collector currents, and you may want to know the gain under this conditions. RG test may be scaled.
     |                   |   Vcc
     /   Rb            /  Rc
     --------------- /       Ge
                         –  gnd
I used to sleep deeply in the classroom, so hopefully, if I understood RG, eqs are:
vc = vcc - ic*.Rc
ic* = ic + iL, iL the leakage current
ib = (vcc- vbe)/Rb
vc = vcc - hfe.ib.Rc - iL.Rc
solving for hfe,
hfe = (vcc-vc).Rb/[Rc.(vcc - vbe)] - iL.Rb/(vcc - vbe)
the value of iL is
iL = (vcc - vc*)/Rc
vc* the value at the collector when Rb is disconnected.
so hfe is
hfe = (vcc-vc).Rb/[Rc.(vcc - vbe)] - (vcc - vc*).Rb/[Rc.(vcc - vbe)]
hfe = (vc* - vc).Rb/[Rc.(vcc - vbe)]    vc, vc*: respect to gnd
Assigning Rb sets the base current ib.Then you can choose a value of Rc so as to make the factor Rb/[Rc.(vcc - vbe)] close to 100, or the number you want. Reading the voltage drop across Rc with Rb not connected, vcc - vc*, and when connected, vcc - vc, substracting and multiplying by 100 or whatever factor you choose gives you the gain under this conditions.
Corrections welcome.
mac
Title: Re: Scaling RG germanium test.
Post by: zbt on October 15, 2022, 04:55:15 PM
May I, Sir?
sorry for the long post
Assume the measurement is repeated, and this is what i did
1. Measure the battery voltage is 9V
    I once used a drop battery (ouch!), so I used a stable supply voltage of 9V, no need worry again
2. What is the leakage value
    Need calculator, vc/2K472, so I used 1K 1% resistor series with 2K trimmer set to 1K472
    V1K * leakage (ex 100uA) would read 0.1V read as 0.1mA, a lot easier
3. What is the actual value of hfe
    perhaps 10uA for ib?
Post by: mac on October 16, 2022, 09:47:06 AM
Quote2. What is the leakage value
Cool!
Quote3. What is the actual value of hfe
1k and 890k.
No quantum precision needed so 890k can be 820k + 68k + 2k2.
Leakage is as your 2) and hfe the collector differences by 100 factor.
mac
Post by: zbt on October 16, 2022, 12:44:46 PM
If 10uA then thing would a lot easier
(https://i.postimg.cc/bDFm3MjH/hfe-Tester.png) (https://postimg.cc/bDFm3MjH)
I should change to 10K for leakage then 1K for hfe
Post by: zbt on October 28, 2022, 06:48:22 AM
added a feature, now i got a stethoscope
(https://i.postimg.cc/GBRFQ4Zp/rmtester.png) (https://postimg.cc/GBRFQ4Zp)
Post by: mac on October 28, 2022, 11:15:03 AM
Add 1M anti-pop resitsors @ input & output.
mac
Post by: antonis on October 28, 2022, 02:12:39 PM
Anti-pop for 5 & 10 nF caps..??
Post by: mac on October 29, 2022, 10:38:30 PM
QuoteAnti-pop for 5 & 10 nF caps..??
Yes.
When I built my RM I did not consider an anti-pop resistor at the output because we are used to have a volume pot to gnd there. But the RM is different, it took me ages to find the problem, I soldered a 100k to gnd, pop gone.
mac
