DIY Stompboxes => Building your own stompbox => Topic started by: PenPen on July 31, 2006, 02:45:02 AM
Title: "Warm" tremolos
Post by: PenPen on July 31, 2006, 02:45:02 AM
I have a request come to me to try designing a custom tremolo. Along with a slew of other features, it was asked to be "warm" sounding, so I am searching for a warm trem circuit to begin learning how some of these things are made. From some quick searches I found that the EA Trem is considered to fit that description, so I'm starting with dissecting that. Anyone have any other suggestions of other designs worth taking a peek at?
Title: Re: "Warm" tremolos
Post by: sfr on July 31, 2006, 03:25:07 AM
What exactly makes a trem sound "warm"?  To me, a "warm" trem is playing softly on the neck p'up . . .
But I really really like my Trem-face clone (using R.G.s schemo at Geofex) now that I fixed it up to account for the lack of unity gain.
Post by: RaceDriver205 on July 31, 2006, 04:23:30 AM
You want "warm" then you want sine-wave tremolo.
Post by: Jack on July 31, 2006, 04:39:09 AM
The schaller tremolo, is ALWAYS described as warm, from it's teeny input z
Post by: Torchy on July 31, 2006, 05:47:19 AM
I cant recommend the Tremulus Lune highly enough.
Ive built the EA (both versions), the Schaller, Anderton's, and a Supatrem clone. For sound and flexibility the Lune wins hands down and ith the Tonepad boards (thanks FP !) its also dead easy to build.
Post by: cakeworks on July 31, 2006, 05:55:54 AM
I was just checking out the tremulus lune on tonepad... what does that LED/LDR do, also what does adjusting the trimpot do?
Post by: Branimir on July 31, 2006, 06:52:16 AM
led/ldr is the part of the LFO (low freq. oscillator), and the trim pot is to adjust the output volume (some replace it with a 100k or a 25k potentiometer for off board volume control).
Tremulus is a great effect, check out my sound samples:
guitar-tremulus-soundcard
http://www.insipidtaste.com/bla/tremolea1.mp3
http://www.insipidtaste.com/bla/tremolea2.mp3
http://www.insipidtaste.com/bla/tremolea3.mp3
http://www.insipidtaste.com/bla/tremulus.mp3
Cheers!
ps: i built the tonepad layout without the ramp up mod
Post by: oldrocker on July 31, 2006, 09:09:28 AM
The Pulsar as is isn't warm per say but its circuit is a simpler design that might be easier to tweek.
Post by: PenPen on July 31, 2006, 12:02:45 PM
Thanks for the suggestions. No, I personally am not certain what "warm" sounds like, but I assumed it to be something with a full frequency spectrum (no cutting out the lows) and a smooth LFO.
I'm going to check out the Lune. Thanks for the sounds clips. Only thing that has me looking more at the EA, I don't see any LDR in there, it is all transistor LFO? If so that may be slightly easier to work with and modify. I need to disect the circuit design, I believe I'm going to need two separate LFO circuits to do the features requested. And a transistor LFO will be easier to put together and test since I have all of those parts on hand.
Post by: R.G. on July 31, 2006, 12:41:14 PM
I sometimes find it amusing that the same people who deride pedals for "tone sucking" also enthusiastically support "warm" overdrives and "brown tone".
"Warmth" and "treble reduction" are synonymous.
Post by: gez on July 31, 2006, 12:48:23 PM
Quote from: RaceDriver205 on July 31, 2006, 04:23:30 AM
I'd go along with that.  By warm, the person probably means that 'classic' sound found in amps such as Fender.
Post by: PenPen on July 31, 2006, 12:53:33 PM
Quote from: R.G. on July 31, 2006, 12:41:14 PM
That is sort of what I was thinking. I'm going to be trimming out a bit of the highs for this pedal, of course I can't actually tell them I'm doing that, just saying it is "warm". Besides, one of the requested features is to give it a low-fi "record wobble" effect, so I'll be cutting those out for that feature as well.
Post by: The Tone God on July 31, 2006, 01:11:50 PM
You could build a Bullitt to get your "warmth". ;)
Andrew
Post by: Branimir on July 31, 2006, 01:46:50 PM
One thing that keeps me amazed when I look at the schem of tremulus is that it's got very few parts and sounds great with lots of controls over the speedm depth, spacing and all, I tried the EA tremolo and it doesn't go as extreme as tremulus...
I have no clue about "warmth", guitar/amp has much more influence on that in this case, at least i think so.
Post by: oldrocker on July 31, 2006, 09:34:54 PM
The Kay Tremolo is not as good as the other trems but I made one and it sounds alright if I use some distortion effects along with it.  I'm thinking about the Tremulus since I hear so much about it.  I really like the Pulsar though and I know most around here don't.
Post by: austin on July 31, 2006, 10:42:41 PM
The Tremulus Lune, as suggested, is a good one.  It does attenuate the highs a bit for a "warm" sound and is fairly easy to build.
Post by: blanik on August 01, 2006, 01:47:03 AM
wich one of those listed above tremolos is best for a really choppy on-off effect (like the intro of that The Smiths song: "How soon is now")?
R.
Post by: RaceDriver205 on August 01, 2006, 01:54:48 AM
Pretty much all tremolos are good for a really choppy on-off sound, once you wind the depth control to max.
Post by: bwanasonic on August 01, 2006, 02:13:50 AM
Quote from: blanik on August 01, 2006, 01:47:03 AM
Keep in mind that the original recording is many tracks of Johnny Marr and Fender amp (twin reverb?) tremolo. No currently available stompbox is going to nail that sound. Not sure what Mr. Marr used live to get *close enough*, but I'm sure I've read about it, maybe even on this forum.
Kerry M
Post by: petemoore on August 01, 2006, 02:16:08 AM
 I think you're building it for someone. The lune has controls you need to find out what kinda dern trem you want. You might get the exact trem you want with "A tremolo', I don't know of a more versatile/~simple one than the Lune.
 Some kind of LP filtering can be added to any tremolo for 'warm'.
Post by: bwanasonic on August 01, 2006, 02:34:19 AM
Well they can be, but as someone who makes a living deciphering people's use of words like *warm*, *cool*,and *hot*, I often find art directors who use these terms in ways that confound accepted norms. Sometimes it helps to get some information on what the client is referencing for their description. Or at least get a couple more subjective terms from them and try and *triangulate* the position of what they are talking about! :icon_smile:
Kerry M
Post by: Jack on August 01, 2006, 05:22:28 AM
You can nail the smiths thing with a single tremolo and a volume pedal in series. Set the tremolo for a deep medium chop, then rock the pedal forwads on the 1st, 2nd, 3rd, 3+, 4, 4+ beats or so, well getting faster towards the end of the bar. It's really not that hard. I've also heard it's a single tremolo with a gate, triggered by a cymbal
Quote from: bwanasonic on August 01, 2006, 02:13:50 AM
Kerry M
Post by: blanik on August 01, 2006, 06:32:14 PM
sorry i might have come wrong, i don't want to have the same sound as the Smiths, i just wanted to know wich DIY tremolo could be really choppy, to sound like i'm switching the signal on and off with a switch... just faster...  :icon_smile:
my twin tremolo isn't bad but it could use just a little more choppyness (and besides, i want a backup pedal so i don't have to rely exclusively on the twin trem....)
R
