DIY Stompboxes => Building your own stompbox => Topic started by: Bucksears on August 25, 2006, 11:19:29 AM
Title: Gotta spare 3-knob box - want a low-gain OD
Post by: Bucksears on August 25, 2006, 11:19:29 AM
I've got an extra (pre-drilled) box that I would like to put a low-gain overdrive in, but the footswitch hole is placed such that I would have to use a small PCB.
Here are my current choices:
GGG Bluesbreaker - I have a circuit completely built that I never boxed up and would just have to label the box and drop everything in.
GGG Dist + - I have the PCB etched, just need to drill it and populate the board. With three controls, I could add the Simple Tone Control and maybe a 'Warp' control on the side of the box.
GGG Blue Magic - haven't even started on this one, so I don't know how small it is.
Given that I already have a ROG English Channel, ROG May Queen, Dr. Boogey, BSIAB II, Big Muff Special, (and a commercial Marshall Guv'nor Plus & Jackhammer on the side), do I even NEED another distortion?
If not one of the three above, what would you recommend? (should I just jump on the bandwagon and buy a Bad Monkey?)
Thanks,
- Buck
Title: Re: Gotta spare 3-knob box - want a low-gain OD
Post by: ildar on August 26, 2006, 12:33:55 PM
I've heard a lot of good things about the Peppermill. I haven't built one myself, but it seems like THE choice around here for a low gain pedal.
Post by: dano12 on August 26, 2006, 02:14:00 PM
Quote from: Bucksears on August 25, 2006, 11:19:29 AM
You can never have enough distortion pedals.
+1 on the Peppermill. Lovely little circuit, I changed a few values to get a bit more gain.
Post by: aron on August 26, 2006, 02:15:24 PM
Quotedo I even NEED another distortion?
HUh? Who keeps saying this????
Post by: wampcat1 on August 26, 2006, 03:55:00 PM
No such thing!!!!  :icon_mrgreen:
Post by: markm on August 26, 2006, 06:41:37 PM
Go ahead Buck......ya know you WANT another distortion!!  :icon_twisted:
Post by: Marcos - Munky on August 27, 2006, 09:39:07 AM
I suggest you the MXR Zakk Wylde OD. It sounds pretty good, something like Lynyrd Skynyrd's "Gimme Three Steps". Also, you can use it to boost another distortion you have.
Post by: QSQCaito on August 27, 2006, 09:46:57 AM
I love my bluesbreaker, good tone range, you can use it as a clean boost if you want.. i think it has very wide options .... im sure you'll find a use to it.
Post by: MartyMart on August 27, 2006, 12:35:45 PM
+1 on the "Bluesbreaker" :D
MM.
Post by: markm on August 27, 2006, 12:43:12 PM
Hey.....
how 'bout a 4 knobber.....
The Fat Boostered  ???
Post by: Bucksears on August 27, 2006, 12:49:26 PM
Thanks for the suggestions guys.
I guess my reason for asking the (rhetorical) 'do I need another distortion?', was more because of the fact that the boxes that I have pretty much cover everything, and I didn't want duplicates taking up space on my board. I'm going build another BSIAB II (for the 5-knob case that my DIY Guv'nor is currently in; another BSIAB II, IMHO, is better than a Guv) and use the extra 2 controls for Gain 2 and Tone 2 and use a footswitch as an additional channel.
I might just box up the Bluesbreaker I already have done as it would save time to not have to build another circuit; it's just going to be a low-gainer that I use for minor, just-above-clean, gritty sounds. I won't use it that much, but I don't want a case to go to waste if I can use it for something.
Thanks,
- Buck
Post by: QSQCaito on August 27, 2006, 01:26:17 PM
Quotejust-above-clean, gritty sounds.
You won0t have problems getting these type of sounds with your bluesbreaker..
Here are some settings that i found long ago.. My favourite is the slight distortion for blues.. These provide a base for, then you tune it up to your personal taste
(http://www.blamepro.com/gifs/bbset.gif)
Bye bye
hope it helped
DAC
