DIY Stompboxes => Building your own stompbox => Topic started by: alexzanderepair on December 14, 2006, 02:52:43 AM
Title: HOW DO I MAKE A VARIABLE CAPACITOR ?
Post by: alexzanderepair on December 14, 2006, 02:52:43 AM
Title: Re: HOW DO I MAKE A VARIABLE CAPACITOR ?
Post by: rockgardenlove on December 14, 2006, 03:20:58 AM
Use a pot to pan between a large value and a small value.
Post by: greenacarina on December 14, 2006, 03:31:25 AM
Or salvage one out of a radio??
Post by: alexzanderepair on December 14, 2006, 03:41:23 AM
rockgardenlove, sorry if i sound retarded but how do i set up a pot like that. im confused
Post by: JimRayden on December 14, 2006, 03:48:02 AM
Quote from: alexzanderepair on December 14, 2006, 03:41:23 AM
Well, you don't have to pan between caps. As two caps in parallel add up, you can use this method (I remember reading about it somewhere):
        Small cap
-----|        ____      |----
     |       |   V      |
   Large Cap   Pot
Jimbo
Post by: mcasey1 on December 14, 2006, 03:50:39 AM
Would this be the equivalent of a simple tone stack?
Post by: alexzanderepair on December 14, 2006, 03:53:29 AM
DOES THE VALUE OF THE POT MATTER?
Post by: JimRayden on December 14, 2006, 04:05:35 AM
Quote from: mcasey1 on December 14, 2006, 03:50:39 AM
When connected to ground (with some additional components), it works the same as any other tone control. Note that it will not act as a real variable cap. It will not change the frequency of rolloff, it will change the slope as tone circuits usually do.
Quote from: alexzanderepair on December 14, 2006, 03:53:29 AM
YES IT DOES. I'LL RUN SOME SIMULATIONS WHEN I GET HOME AND DECIDE ON IT'S VALUE. IF ANYONE CAN TELL A VALUE FROM THE TOP OF THEIR HEADS, I'D APPRECIATE THAT.
UNLESS YOU HAVE A FAULTY CAPSLOCK, I'D HAVE... ahem... I'd have to ask you to stop writing in capital letters, as it is considered yelling on internet communities. No offense.
Jimbo
Post by: The Tone God on December 14, 2006, 04:06:50 AM
We are missing information to give a concise answer. What value range are you looking for ? What type of signal are you attempting to control ?
Andrew
P.S. Please don't use all caps. The shift key is not that hard to use.
Post by: alexzanderepair on December 14, 2006, 04:12:03 AM
sorry for the caps thing.
the range is 0.005uf to 0.068uf
trying to control the sweep range on a wah
Post by: Ge_Whiz on December 14, 2006, 04:29:19 AM
You can't make a true variable capacitor in the nanofarad range, and the 'pan-pot' idea will not work for what you want to do here, sorry.
Post by: zachary vex on December 14, 2006, 04:47:23 AM
i seem to recall something about a beaker of fluid and some plates and wires...
Post by: The Tone God on December 14, 2006, 04:55:46 AM
Quote from: zachary vex on December 14, 2006, 04:47:23 AM
That was just foreplay. :icon_twisted:
Andrew
Post by: rockgardenlove on December 14, 2006, 05:08:49 AM
Quote from: JimRayden on December 14, 2006, 03:48:02 AM
        Small cap
-----|        ____      |----
     |       |   V      |
   Large Cap   Pot
Jimbo
That's an option too, probably better than mine.  Both will work though.
Post by: bancika on December 14, 2006, 06:48:27 AM
why don't you just use rotary switch with as many positions as you need with different cap connected to each pole. That's usual way of doing variable wah sweep
Post by: StephenGiles on December 14, 2006, 08:10:55 AM
Why can't just buy one?
Post by: Paul Perry (Frostwave) on December 14, 2006, 08:15:42 AM
Quote from: StephenGiles on December 14, 2006, 08:10:55 AM
welll...... an air cored variable cap in that value range is about 1,500 cubic inches. It's going to be a tight fit, plus not that easy to adjust :icon_smile:
In theory, you could make something cute using a cap synthesised from OTAs, but I'm sure it wouldn't be practical. Go switched.
Post by: R.G. on December 14, 2006, 09:10:41 AM
At the risk of confusing things, this is easy, at least in theory.
Method 1: Switched Capacitors
If you put a capacitor in series with a switch and turn the switch on and off very rapidly, then the current that flows through the capacitor depends on the voltage across it when the switch is closed and the proportion of the time the switch is closed. If you run the switch at a high enough frequency, the apparent capacitance looks like the real capacitor times the duty cycle.
So I think that you can do this with a PWM setup and a CMOS switch, possibly a JFET switch.
Of course, you have to pay Mr. Nyquist his due, and make the switching frequency be more than three times the highest frequency in your signal, preferably above the audio range so you can't hear switching artifacts.
Method 2: Capacitor DAC
Make an R-2R ladder out of capacitors. Switch the ladder nodes with CMOS or JFET switches controlled by a binary encoder set up to look like a pot. The effective capcitance then varies in about 1/2% steps, appearing completely smooth to a human.
Method 3: Sythesized capacitor
Set up a synthetic capacitor circuit along the lines of a gyrator, but with capacitors.
There are others but they're much more limited in scope.
For instance, the way I sense water level in the rainwater tanks: drop a loop of insulated wire into the tank, all the way to the bottom. Hook both bare ends together at the top. Stick an electrode in the water. The capacitance between the wire sensor and the electrode is linear with the depth of the water from some non-zero minimum to some maximum when the water covers up all the wire it can. The water acts as a conformal second capacitor plate to the wire through the insulation.
Post by: tungngruv on December 14, 2006, 09:55:31 AM
(http://happybob.com/marc/circuits/variablecap.gif)
Post by: johngreene on December 14, 2006, 02:02:15 PM
That is only a capacitor when the pot is shorted. Any other setting of the pot results in a RC network, not the same thing as just a 'capacitor' of a different value.
--john
Post by: greenacarina on December 14, 2006, 02:55:30 PM
http://www.mouser.com/search/Refine.aspx?Ne=254271+1447464&Ntt=*variable*%20*capacitor*&Ntx=mode+matchall&Ns=P_SField&Mkw=variable%20capacitor&N=1323038%20254271&Ntk=Mouser_Wildcards
Post by: zyxwyvu on December 14, 2006, 03:38:13 PM
Not sure how practical this is for a pedal, but this will get you a large range of variable capacitance:
http://home.earthlink.net/~lenyr/varelec.htm (http://home.earthlink.net/~lenyr/varelec.htm)
