Where can I get these pots?
(http://www.beavisaudio.com/images/nc_redux.jpg)
Hey you can buy them from Mouser and most other places. They are about 3 bucks a pop at Mouser. :icon_cry:
They are about £3.50 in the UK !!!
Is there a makers name on them? And what is the size in mm? If it is 9mm Alps make some (around $2 in Aust) tht work, but I have also seen some horrible knockoffs.
Man, I've been looking everywhere for those, I think alpha some like that, and yes they are curiously expensive on mouser, and in limited values/tapers. I can't find them anywhere else, at all. Boss uses them, though, and so does Zvex. I can't imagine boss especially paying twice as much for those as the 16mm alpha's we're used to.
SBE will start to carry PC mount Alpha pots later this year. It will take me some time to gear up because of factory lead times and capital constraints, but it will happen, like some of my other made-to-order stuff, and for the same reason: There are many small boutiques that would like to build around these parts, but the high price/limited choices from Mouser make it difficult. Stay tuned.
SD
These are Alpha 9mm PCB mounts. Mouser has them:
http://www.mouser.com/search/ProductDetail.aspx?R=311-1901F-10K (http://www.mouser.com/search/ProductDetail.aspx?R=311-1901F-10K)
The are crazy expensive, and I buy 20-30 at a time. If they were cheaper, I'd use them a lot more.
I believe you can get them for under US$0.75 each - if you buy over 5000 pieces of each value per order. :icon_cry:
