DIY Stompboxes => Building your own stompbox => Topic started by: vince on April 12, 2007, 05:23:18 PM
Title: 78L09 setup
Post by: vince on April 12, 2007, 05:23:18 PM
Hey guys,
I am building a power supply based on a 78L09 regulator. Most schematics using it have cap. values of over 100 uF.
But the typical application page in the datasheet is as follows:
(http://i179.photobucket.com/albums/w294/thrice24/78L09.jpg)
Is there any explanation for choosing higher cap values than specified?  The time constant is definitely higher, which means less ripple. BUT.. I am thinking 0.33 uF and 0.1 uF must already be more than enough.
Thank you
Vincent
Title: Re: 78L09 setup
Post by: Paul Perry (Frostwave) on April 13, 2007, 09:50:29 AM
C1 value depends on where the unregulated DC is coming from.
If it is coming from a wallwart with a decent sized (say 500uF) cap inside it, then a small one near the reg is OK.
But if you are running AC into the box & rectifying it, then 500 or 1,000uF might be needed, depending on current load.
Post by: Crevil on April 13, 2007, 10:19:12 AM
A good rule of thumb is using a cap at the approximated amount of current you are going to neat.
If you are going to use 800mA then a cap on 800uF will normally do, then if you are going to make it more silent, put a 100nF after the 78LXX, if you can get some Sibatit caps that will be perfect, they are really good at killing noise, but they are also often hard to get.
This is just a rule of thumb, not something specific, and used most when speaking of supplyes using AC.
Post by: Sir H C on April 13, 2007, 11:48:53 AM
The output one is too small in my opinion.  That capacitor is to handle spikes which are too fast for the regulator, so you usually would want at least 1uF there, not too big here though.
And what does Note 2 say?
Post by: vince on April 18, 2007, 12:06:27 PM
Quote from: Sir H C on April 13, 2007, 11:48:53 AM
NOTE 2. Bypass Capacitors are recommend for optimum stability and transient response and should be located as close as possible
to the regulator
We already knew that !  :icon_biggrin:
The transformers are rated 60 mA I believe, so there won't be a lot of current going through the regulator.
I guess a 500 uF capacitor for the input would be enough, right?
But I'm not exactly sure of the purpose of the output capacitor. Should I use a very low value, like 100 nF as suggested and also a bigger one, like 10 uF ?
Vincent
P.S. Sorry if this topic was brought back from the dead, but I was working on another project
Post by: Steben on April 18, 2007, 12:16:52 PM
Wohow! 800 and 500? Ar we talking "micro"farads? That are big whoppers!
Post by: vince on April 18, 2007, 02:18:48 PM
Quote from: Steben on April 18, 2007, 12:16:52 PM
Yeah, we're talking micro Farads. Good power supplies generally have capacitors from 500 to 1000 uF after their diode bridge, to reduce the ripple to minimum. When I was in university, we once built a precision power supply, and we used 10 000 uF capacitors! Those were huge!
But in this case, they only have to be rated 16V, so they won't be very big.
