DIY Stompboxes => Building your own stompbox => Topic started by: Bucksears on April 13, 2007, 10:59:28 PM
Title: Did I fry my ge transistor?
Post by: Bucksears on April 13, 2007, 10:59:28 PM
I finished up my GGG '69 Fuzz Face (neg. ground) tonight and it had no sound at all. After checking it over again, I had Q2 in backwards.
It was on for all of 5min.; is it possible that I fried it?
I haven't had an opportunity to try it out correctly due to the late hour tonight.
Thanks,
- Buck
Title: Re: Did I fry my ge transistor?
Post by: reverberation66 on April 14, 2007, 12:12:33 AM
   seems like it should be fine, I think some of these fuzz circuits will still work even with the transistors in backwards.
Post by: darron on April 14, 2007, 07:53:58 AM
Quote from: reverberation66 on April 14, 2007, 12:12:33 AM
yeah. i don't think that will damage it. i've even shorted positive and negative together accidentally over night with a battery in it. worked fine still, thought the 1000uf capacitor i used to prevent motorboating nearly exploded out of it's case! i guess most of the heat got burnt off in there and expanded it. probing it incorrectly in my dmm hasn't damaged the transistors either. they were ac128's
Post by: zjokka on April 14, 2007, 08:20:39 AM
like this?
http://www.muzique.com/lab/reverse.htm
Post by: R.G. on April 14, 2007, 09:11:19 AM
QuoteI finished up my GGG '69 Fuzz Face (neg. ground) tonight and it had no sound at all. After checking it over again, I had Q2 in backwards. It was on for all of 5min.; is it possible that I fried it?
Is it possible? Yes.
Is it likely? No.
Germanium devices are sometimes more robust about being reversed than silicon, at least the devices made before planar processing. A very few of those older devices are actually symmetrical - the base-emitter and collector base junctions are almost alike.
Try it. Likely you'll be fine.
Post by: petemoore on April 14, 2007, 10:03:57 AM
  I somehow ended up with some SB transistors [so, good'], which are fried, at the time I was building and tweeking TB's FF's and RM's.
  For my initial tests, after battery non-shorting test, I'd pop in some 2n3906 or other ROTM PNP, until I got some sound and nothing way out of whack voltage wise, then apply the GE's.
  Then I'd test transistors in the DMM"s hfe sockets, or just put them in a known working circuit.
