DIY Stompboxes => Building your own stompbox => Topic started by: yeeshkul on October 17, 2007, 04:46:15 AM
Title: Rangemaster clone - volume question
Post by: yeeshkul on October 17, 2007, 04:46:15 AM
I am going to add a volume pot to the RM output.
Does it make any difference if i put the output cap on the output lug of the volume pot instead of leaving it before the pot (where is should be normally)?
thanks
Jan
Title: Re: Rangemaster clone - volume question
Post by: JHS on October 17, 2007, 05:14:09 AM
YES. The first sulution is technically crap. with the 10k pot on zero and with closed Vol-pot you produce a short cut in the power supply.
JHS
Post by: yeeshkul on November 02, 2007, 07:05:09 AM
guys what pot would you use for the RM volume? 100k, 250k, 500k audio pot?
Post by: Gus on November 02, 2007, 10:49:36 AM
I would not use an external vol pot.   I would build it stock with a pot for the collector resistor
Post by: Dragonfly on November 02, 2007, 01:30:37 PM
Alternately, you could set it up normally, except using a 20k trimmer instead of the normal volume pot....then put a 100k-a pot AFTER the cap, wired like you would normally wire a volume pot.....set the trimmer where you like the sound BEST....that way you have the best of both worlds.
Post by: yeeshkul on November 02, 2007, 02:25:40 PM
thanks, i'll check it out :)
Post by: DougH on November 02, 2007, 06:33:55 PM
Why do you want a volume pot?
Post by: yeeshkul on November 03, 2007, 05:02:15 AM
I am making RM for my friend who wants less/no difference between volume of the clean sound and when RM is on, but he wants to keep the full RM sound. I mean a normal RM, just not that loud when the Drive(collector pot) is full blast.
Post by: tenchijin2 on November 03, 2007, 07:06:42 PM
Guys, I'm pretty new to this but...
The point of a treble booster is to boost the signal and overdrive the amp. So if you reduce the volume after you boost it isn't it going to *not* drive the amp? The pedal doesn't actually distort the guitar sound directly.
I use a Brian May Range Maistro pedal (a Rangemaster variation). Really it's best to leave it on all the time and use the guitar volume pot for altering the tone/overdrive while you play.
It sounds like your friend wants an actual distortion pedal, which has an output control that allows the distorted output to be equivalent to the bypassed output.
I don't think that's at all viable with a treble booster.
Aric
Post by: yeeshkul on November 04, 2007, 07:25:52 AM
i'd say RM distorts the signal  - it is biased to -7V not to -4.5V as usuall.
Post by: Gus on November 04, 2007, 09:28:21 AM
Jan carefully read the writeup at Geofex about drive to the first grid.   If you ADD a volume pot you are adding series resistance when the pot is not at max.
Now this might not matter or it might if your friend likes the sound of the stock circuit into a certain amp (guitar, treble boost, amp)
You should be able to set the pot to a certain level and just.  Now if it turns out your friend likes the drive into the grid
Add a EF
OK
treble boost
10K (whatever one likes) collector resistor
collector to a 1uf to 100k lin pot as volume
1uf cap to base
NPN 2n5088 as an emitter follower
10K emitter
1meg base to ground
470k base to +9V (yes offset on purpose)
1uf film out 100K, 1 meg etc pulldown
One can do the math with the 1uf caps for different values and use what type you like.
Post by: yeeshkul on November 04, 2007, 12:01:04 PM
Gus please tell me what is the reason for EF stage here (at the end of the circuit)?
Post by: yeeshkul on November 04, 2007, 01:40:13 PM
I mean i was playing with Astrotone fuzz some time ago - it has EF after the gain stage as well. In the end i put the EF in front of the gain stage ... and i was really happy with the sound and fairly big input impedance. Here you suggest to use EF after the gain stage again which makes me a bit confused ...
Post by: mattumbi on November 04, 2007, 07:25:00 PM
Quote from: yeeshkul on November 04, 2007, 12:01:04 PM
You'll have to read the GEO article, its about driving the grid of the amplifier.
Post by: DougH on November 05, 2007, 07:43:38 AM
Quote from: yeeshkul on November 03, 2007, 05:02:15 AM
Well, the "full RM sound" is partially due to the way it drives the amp. You can try it on a breadboard with a volume pot on the output. I suspect it won't sound very impressive. It will distort slightly and will emphasis treble, but it's not the same. The RM is a very synergistic effect- it combines with the sound of your amplifier and the overall sound depends a lot on the interaction between it and your amp. Over the years I've seen a few diy designs of overdrives with "rangemaster input stages". Some people use an RM to drive their fuzz face or other distortion or overdrive boxes too. You may want to investigate some of these ideas too, to get a "volume controlled" rangemaster effect. All you can do is read up on what makes it do what it does, and try things out on the breadboard until you find something you like.
Post by: yeeshkul on November 05, 2007, 08:47:33 AM
All right i understand. To be honest i had the board made for it already, so i am a bit trapped now since i promised to make it soon :). I will see what i can do and put the result here soon. I will try to add one germanium diode after the output cap (switchable). If i understand well, due to the bias that is not in the middle one diode may be enough. That may help to distort the sound although it won't be rangemaster any more - that's why it will be just optional.
Post by: DougH on November 05, 2007, 09:13:37 AM
If you mean you are going to add a Ge diode as a shunt on the output- that's a bad idea. Why? Ge diode fwd voltage drop is less than .5v, usually around .3v or .4v. You will be severely limiting the output voltage swing available, and your volume control will barely reach unity gain when it is turned up all the way.
edit: You can string multiple diodes in series to increase the effective fwd voltage. I still don't think it will sound "right", but give it a try.
Post by: yeeshkul on November 05, 2007, 09:41:44 AM
Dough thats true, but i just want to reach what my friend wants - no volume step between clean and distorted sound. I know that RM is really a bad choice for this request. I am just going to do things now so i will see in a little while. But i completely understand what you mean.
Post by: d95err on November 05, 2007, 01:15:11 PM
If you want something like the distortion sound associated with the Rangemaster, take a look at e.g. the May Queen. It's an overdrive designed to sound similar to a treble booster pushing a low gain tube amp:
http://www.runoffgroove.com/mayqueen.html
If you want to salvage the circuit you're already building, try adding a FET gain stage after the Rangemaster (to simulate the first stage of the tube amp being pushed into distortion), and then a master volume. It should be possible to do with just a few components. No need for a PCB, just connect the component legs point-to-point. Checkout the Fetzer Valve and use the appropriate parts of that circuit:
http://www.runoffgroove.com/fetzervalve.html
Trust me, the Rangemaster by itself sounds thin and buzzy and generally terrible. You couldn't possibly imagine that it could be turned into something good, just by turning it up and having it push an amp...
Post by: d95err on November 05, 2007, 01:29:14 PM
Another note (not sure if it was described by anone else) - the regular volume control on a Ragemaster is exactly that - a volume control. It does not change the amount of distortion created in the circuit. So it makes no sense to add an extra volume control after it.
Post by: Dragonfly on November 05, 2007, 01:32:10 PM
Quote from: d95err on November 05, 2007, 01:29:14 PM
Actually, give the trimpot into volume idea a try..it might just surprise you...the variation is subtle, but definitely there.
Post by: yeeshkul on November 05, 2007, 02:10:14 PM
that sounds like a solution !
Post by: Gus on November 05, 2007, 03:26:07 PM
Jan I am not sure what you are looking for from the posts in this thread.
Does your friend like the RM with the volume at max or close to max?
If so what you want might not be possible.
Think of the RM as another gain stage in your friends amp.  It is EQing and boosting the preamp so it is a TOTAL system sound change.  If the volume is reduced the preamp is not being distorted like your friend likes it from the EQ and boost of the RM
Maybe something that might work is a clean opamp booster with a fixed gain of 3(to keep it clean at 9VDC) with a volume pot and the RM.
You switch between the outputs of the RM or booster set for about the samevolume.
This is still not the same but maybe  closer to what your friend wants
Post by: yeeshkul on November 05, 2007, 03:46:34 PM
Gus unfortunately i'm convinced he wants me do impossible. I just started playing with the idea of the J-FET stage after the RM with the master volume. I have never worked with J-FETs though. I seems like they use mostly J201, but i cannot find it here. I found BF245A, which seems to be quite close to that one.
Post by: yeeshkul on November 06, 2007, 12:25:57 PM
I added the Fetzer Valve after the Rangemaster stage. The sound is quite strange though, it is not consistent - like missbiased although i have 4.5V on drain. I used BF245A J-FET. Actually are there any parts of Fetzer Valve (as described at http://www.runoffgroove.com/fetzervalve.html ) i should omit?
I just put the Fetzer valve the way it is right after the output cap of the RM. Do you guys have any idea what may be wrong? I have never worked with FETS and to be honest i don't know much what i am doing here :)
I have 2 J-fets now:
BF245A with Vp: 1.94V / Idss: 5mA (measured)
J112 with Vp: 3V / Idss 40mA
i cannot find J201 here :(
Post by: DougH on November 06, 2007, 01:10:12 PM
Make sure you have the jfet pinout correct. You can leave out the 68k but it won't hurt to leave it in.
Post by: yeeshkul on November 06, 2007, 01:15:51 PM
pinout is correct - i checked data-sheet. It sounds much smoother when i leave out the 1M resistor, is that normal?
Post by: yeeshkul on November 06, 2007, 01:20:16 PM
however when i remove the 1M, bias goes to 8V at drain and the dtain trimpot (50k) doesn't have any influence....
Post by: yeeshkul on November 06, 2007, 01:32:50 PM
oh, i just realised that Fetzer Valve works with negative ground :):). I guess i will need some sort of a P channel  j-fet.
Post by: DougH on November 06, 2007, 01:44:07 PM
No, you use an N-channel JFET. You will need a ground reference on the gate. Leave the 1M in. This is why the bias is getting messed up when you remove it.
Do you have a coupling cap on the output of the JFET circuit?
Post by: yeeshkul on November 06, 2007, 02:03:35 PM
Yes i have 47n cap on the output (i have no volume pot added yet though). I will put the 1M back in, but Dough how come i can use N-FET in my positive ground circuit. Sorry for my silly questions, i am just reading about FETs, trying to get into it.
Post by: yeeshkul on November 06, 2007, 02:10:45 PM
do i have to turn the schematics sort of "upside down" with the 1M from gate to -9 and so on?
Post by: DougH on November 06, 2007, 02:24:57 PM
Oh, I see what you're saying. The RM is a pos-gnd circuit. Hmmm...
Why don't you draw a schematic and we'll go from there. It will be easier to figure out with a picture.
edit: If you want to try a P-channel JFET and make the JFET circuit positive ground, that would be the simplest solution.
Post by: yeeshkul on November 06, 2007, 03:46:37 PM
I guess i am gonna get one and keep elaborating tomorrow  ;D
Post by: yeeshkul on November 07, 2007, 09:43:25 AM
I am finally through it!
I got 2N3820 P-FET today (measured Vp=2.43V, Idss= 2.5mA) and added the Fetzer Valve circuit after RM stage. And it works and sounds great. And with the master volume you can play quited&distorted sound (which is smooth, with consistent sustain). I am so glad you guys here helped me!
The 22uF cap in source gives it actually a nice boost so i am not sure if i use deluxe version of the FV circuit (omitting the cap) yet.
I'm gonna actually  build one for myself with a RM/RM+FV switch, i think the 1M resistor can work like pulldown for RM itself when the FV is cut off.
Post by: DougH on November 07, 2007, 11:18:34 AM
Glad you got it working!
Have fun.
Post by: evaninsky on August 17, 2010, 02:47:26 PM
I'm glad you figured this out !!  can you explain it to me...  maybe a schematic of the FV ?
Post by: jaysg on August 17, 2010, 07:02:42 PM
The Rangemaster third of the BYOC TriBoost has a 100K level pot at the tail end.  The RM 10K pot is just a 10K resistor.   I'm not sure exactly what the OP was planning, but you don't want two pots on it.   It sounds fine to me.
Post by: newfish on August 18, 2010, 06:07:50 AM
I have a fixed 10k resistor in place of the original gain pot, and a 250K pot after the output cap.
I figured I can have the transistor working overtime *all the time* to provide that lovely 'break-up' sound - but at a controlled level for feeding in to a Fuzz Face.
This combination allows a host of different Fuzz / High Gain combinations depending on how much RM signal is fed into the FF.
...plus, I can adjust the RM's volume without the pot being scratchy, as it tends to be when adjusting the DC going into the tranny.
