DIY Stompboxes => Building your own stompbox => Topic started by: nooneknows on November 15, 2007, 08:00:18 AM
Title: ROG Tube Reamer rules!
Post by: nooneknows on November 15, 2007, 08:00:18 AM
in the past I've already built the original ROG Tube Reamer, good but I've never used it so much, it worked in way a bit strange with the gain control.
Yesterday I've built the 2nd version using the ROG perfboard layout as a guide and put it in the old box.
Wow.
It sounds very, very, very good, my strato in a Marshall JCM800 and in a Peavey Classic 30 (heavily modified, more like a Fenderish amp now) produces a tight and pleasant mid distorted tone, very dynamic.
My only complain is the Volume, waaaaaaaaay to high for me, but no problem, taming the volume pot down is enough.
A very nice pedal, ROG guys, you are great, thank you.
bye,
Marcello
Title: Re: ROG Tube Reamer rules!
Post by: wampcat1 on November 15, 2007, 09:59:45 AM
Quote from: nooneknows on November 15, 2007, 08:00:18 AM
Wow.
bye,
Marcello
Hi Marcello,
Very true - a great sounding circuit! :)
You might try running a voltage divider before the volume pot to make the volume pot a little more usable. IIRC, I used a 100k resistor in series with the signal and a 47k to ground, then that into a 100k audio pot. Worked very well as I remember.
Hope that helps! :)
bw
Post by: B Tremblay on November 15, 2007, 12:39:51 PM
I'm happy to hear that you're enjoying the circuit and that you found the revisions to the original to be an improvement.
You can reduce the output volume by replacing the feedback resistor with a smaller value in the gain recovery stage.  Try a 27k in place of the 51k for half as much gain.
Post by: km-r on November 15, 2007, 09:25:40 PM
+ 1,000,000
i like mine too! used LEDS though... very nice use for tube amps!
Post by: MartyMart on November 16, 2007, 04:07:16 AM
I'm with you on that, V2 is a different beast and getting close to the real thing but it's a little gem !
MM
Post by: B Tremblay on November 16, 2007, 06:20:53 AM
Quote from: MartyMart on November 16, 2007, 04:07:16 AM
...but it's a little gem !
No, the Little Gem is an amp, silly!  :P
Post by: MartyMart on November 16, 2007, 06:34:12 AM
Quote from: B Tremblay on November 16, 2007, 06:20:53 AM
Ha , you got the "pun" then !!  :icon_wink:
