DIY Stompboxes => Building your own stompbox => Topic started by: Cardboard Tube Samurai on April 13, 2008, 07:49:51 AM
Title: Getting goop off PCBs?
Post by: Cardboard Tube Samurai on April 13, 2008, 07:49:51 AM
So I'm attempting to troubleshoot a pedal for a friend. It's a fuzz made by BSM and it has started gating the sound with a really horible decay. I figure it just needs re-biasing or something to that effect. Anyway, I have just spent the better part of the last hour trying to open up the black box inside the enclosure to get to the PCB, only to find that the PCB is covered in goop. Is there any way to get the goop off the board? What's a trouble-free way to get this stuff dissolved or just gone... somehow!?  ???
Title: Re: Getting goop off PCBs?
Post by: Mark Hammer on April 13, 2008, 08:03:11 AM
1) If you don't know what yu're doing, removing the goop might damage the pedal further.
2) BSM charge enough for their pedals.  I would think they would rather have you ship the board to them and supply you with another than have you attempt to ungoop the device, wreck it, and create false impression of their product in potential customers.  Give them a shout, describe the problem and ask if you can do a board swap.
Post by: Cardboard Tube Samurai on April 13, 2008, 08:07:45 AM
The guy I am doing this for has already replaced the pedal with another from BSM. Considering the damage I have done to the black plastic box that encases the PCB, I doubt that BSM would be all that willing to help out.
Post by: Mick Bailey on April 13, 2008, 08:21:10 AM
It depends on what the goop is - epoxy, silicone, polyester, acrylic etc.
Someone I know worked for a company that could remove some types of goop using solvent gels and scraping away layers of softened material. Must have been component-friendly, though - not paint stripper or acetone. Should think that a while spent searching may turn something up that's commercially available.
Depends on the time and cost to do the job.
Post by: killerkev on April 13, 2008, 02:38:59 PM
I came across this:
http://www.crosslinktech.com/FAQ/Removing%20cured%20products.htm
Post by: Cardboard Tube Samurai on April 13, 2008, 04:55:34 PM
Hmmm... so it's a prick of a job. I have been in contact with BSM and explained the situation. They have asked me for the serial number and I'm guessing that's so they can check if it's still covered by warranty (3 years on electronics). I told them about damaging the box too... I guess we'll see what happens
Post by: R.G. on April 13, 2008, 11:08:00 PM
Do the search. I've typed this in here a couple of times.
Post by: Paul Perry (Frostwave) on April 14, 2008, 12:31:37 AM
Can't be anything TOO special in there , or they wouldn't have bothered to goop it!
