DIY Stompboxes => Building your own stompbox => Topic started by: alcoloic on June 18, 2008, 11:21:29 AM
Title: dual valcaster question
Post by: alcoloic on June 18, 2008, 11:21:29 AM
hi everybody
i build the dual valvecaster using this unverified schematic
http://www.beavisaudio.com/Projects/ValveCaster/twincaster.gif
it work great but the gain control of the second tube has no effect .
does anyone have the same problem ?
thanks
Loïc
Title: Re: dual valcaster question
Post by: frequencycentral on June 18, 2008, 12:59:59 PM
I have only built single tube versions. But try unhooking the two stages and see if the second stage gain works as a standalone maybe???
Or maybe the second stage is just so saturated by the first???
Post by: alcoloic on June 18, 2008, 01:22:21 PM
Quote from: frequencycentral on June 18, 2008, 12:59:59 PM
thanks for helping
i was actually asking myself the same question .
i've read a good part of the 29 pages valvecaster thread and i didn't notice anyone talking about it
Post by: Renegadrian on June 18, 2008, 01:27:03 PM
Yes, I still haven't build a two-valver myself...So... ???
Post by: ambulancevoice on June 18, 2008, 07:02:49 PM
hmm, i think dano made a mistake
shouldnt the 1 uf cap on v2a (called v1a on the schematic) go the grid not the plate?
try that, disconnect the 1uf cap on v12 and connect it to the grid
might be why its not working
Post by: frequencycentral on June 18, 2008, 07:43:26 PM
Yes, looking at the schematic, Alex is right, that cap should go to pin 2. I think the schemo misses out the third triode altogether.
The 100K above the second triode should be connected to 9v too.
Post by: ambulancevoice on June 19, 2008, 03:51:53 AM
like this
(http://img398.imageshack.us/img398/2199/twincasterbt1.gif)
you should probably power it on 12v dc too
Post by: alcoloic on June 19, 2008, 10:58:51 AM
thanks a million guys it's working now
Post by: wavenator on June 19, 2008, 12:58:27 PM
good to hear that
btw
how's the twin?
it has a lot of gain?
Post by: alcoloic on June 19, 2008, 04:53:34 PM
i don't know what you define has a "lot of gain" but to me that's a lot of gain !!!
it's actually a cool sounding distortion when both tube are engaged but it really kill the sustain (high notes fade away in about 2sec)
maybe my second tube is dead ! i used some crappy ehx tubes btw
Post by: ACS on June 19, 2008, 07:16:15 PM
Sounds like a bias problem maybe?
Post by: wavenator on June 19, 2008, 07:18:55 PM
it sucks
2 sec?
change the R3's and R2's to trimmer and try to bias the tube
Post by: alcoloic on June 20, 2008, 11:39:55 AM
i tried that but with no results .
this is really strange i have a 3pdt to switch the second tube ; when the second tube is engaged i have a cool sounding disto but if strum hard on my guitar all the hiss disappaer and the disto become gated and farty
then i switch off then on and it works again
Post by: frequencycentral on June 20, 2008, 12:19:35 PM
Can I ask what power you are supplying to the circuit? The power requirement of two tubes would be 300ma plus, assuming your not using the centre tap of the heater, which I think would double this to 600ma.
Personally , I would run what you have built from a 12 volt 500ma regulated wallwart, using the two tube heaters at 12 volt (paralleled) and ignoring the centre taps (pin 9).
Post by: ambulancevoice on June 20, 2008, 06:57:40 PM
try this
see on the first tube stage, the 1M resistor to ground after the input cap at the grid
well, do the same with the second stage, add a 1M resistor to ground after the 1uf cap
Post by: Renegadrian on June 21, 2008, 02:52:13 AM
Isn't that just a pull down R?
Post by: snap on June 21, 2008, 03:36:01 AM
It is called different, but in deed pulls down the grid to ground DC-wise, and also references the gridside of C3 to a fixed potential so it can`t float around wherever the electrons send the floating gate beyond control.
It is absolutely neccessary there.
Post by: ambulancevoice on June 21, 2008, 05:16:09 AM
Quote from: Renegadrian on June 21, 2008, 02:52:13 AM
also, its not because pull down resistors (pop removal ones) are always before the input cap and after the output cap, when needed, usually the volume pot acts as a pull down resistor.
Post by: Renegadrian on June 21, 2008, 12:35:59 PM
'K, learnt something more...So do you think it's mandatory to duplicate that R1 on the second part of the circuit?
Is it meant to be right after C3?
Post by: Jimmy-H on June 21, 2008, 02:20:29 PM
Quote from: snap on June 21, 2008, 03:36:01 AM
It is absolutely necessary there.
Yeah you are right about that.
If you look at the pepper shredder schemo, they use 220K resistor right after the capacitor : http://www.tube-town.net/diy/lov/lov02-peppershredder.jpg
And C3(1) doesn't have to be 1uF, it can be a smaller one just like the C1.
Post by: Renegadrian on June 23, 2008, 03:20:02 PM
I added a new VERO version with that correction - it should work - Please check it out!!!
In the LAYOUT GALLERY search for TWINCASTER.
PS actually it's 2 layout, with and without the R1 at the beginning at the second stage.
Post by: alcoloic on June 23, 2008, 04:18:08 PM
hi everybody thanks for all the answers
yeah it's much better with the second r1
frequencycentral thank you ! you made me realise the wallwart i was using was only 200 ma !!!
i always use my fx with different sources (bass guitar synth sampler etc ) so i have already put two switch for mods ! if anyone has a suggestion
anyway thanks a lot everybody
Post by: Renegadrian on June 23, 2008, 05:01:09 PM
Quote from: alcoloic on June 23, 2008, 04:18:08 PM
So did you try with and without R1b having the right wall wart???
Post by: frequencycentral on June 23, 2008, 05:47:32 PM
Try an R1 value of 100k for synths, and perhaps 5M to 10M for microphones, depending on the type. Try it and tell me your results!
Post by: mitzrecords on November 19, 2008, 01:15:06 AM
hi, just wondering if anyone else built this thing.
I just built single one and love it! but i wanna more gain. i wanna try this.
if you have pics or layout would be much appreciated to guide through and double check.
thanks bunch.
ps im so addicted to building pedal. i spent too much money on parts last three weeks :icon_wink:
Post by: Renegadrian on November 19, 2008, 07:22:19 AM
Quote from: mitzrecords on November 19, 2008, 01:15:06 AM
As I wrote above, In the LAYOUT GALLERY search for TWINCASTER.
Post by: mitzrecords on November 20, 2008, 12:03:49 AM
Quote from: Renegadrian on November 19, 2008, 07:22:19 AM
oops, sorry. got it!
thank you! :icon_redface:
Post by: kurtlives on November 29, 2008, 12:00:53 AM
Ive been playing with a design similar to this for the last two nights on the bread board. Getting great results...
Ditch the pots on the cathodes, no idea why you would want them on a cascading circuit like this. Instead I replaced them with 16K resistors, you could use lower values for more gain. I am also using a DIP switch to add a cathode bypass cap in parallel to those resistors, gain boost switch!
Anyways to add the gain control I am just adding a variable voltage divider between the two stages, essentially a volume control. Also between the two stages I added a tone stack.
Also with all these stages cascaded I needed to adjust the coupling networks. Cut most cap values in half. Also reduced the plate resistors value, more so in the first stage.
Also I have the heaters running at 12V regulated and the rest at 30V regulated. Sounds amazing, a good step up from 12V. Lots of tone, I dig.
