DIY Stompboxes => Building your own stompbox => Topic started by: vasko on August 18, 2008, 06:05:11 PM
Title: single penthode guitar preamp???
Post by: vasko on August 18, 2008, 06:05:11 PM
is it possible to make such preamp?
I'd like to use ef80.I also have ecc82 triode.
It has to have gain,treble and bass knob.
I want to use it to attach guitar with PC line in.
Title: Re: single penthode guitar preamp???
Post by: frequencycentral on August 18, 2008, 06:07:09 PM
Single dual triode is well documented: http://www.diystompboxes.com/smfforum/index.php?topic=63479.0
Or two dual triodes:
http://www.tube-town.net/diy/lov/lov01-vanillaoverdrive-eng.html
http://www.tube-town.net/diy/lov/lov02-peppershredder.html
You could add a Fender or Marshall tonestack.
Post by: Renegadrian on August 18, 2008, 07:19:01 PM
ATM there's not much about pentodes...I got some and will start breadboarding in a while...Until now, you can find a couple of 6418 projects in the gallery. See if they may be helpful....
Got ECC82??? BUILD A VALVY!!!  :icon_wink:
Post by: Jimmy-H on August 19, 2008, 12:33:47 AM
Quote from: vasko on August 18, 2008, 06:05:11 PM
Only found this, but it's with a different tube 6AU6 en 36volt DC : http://jonanderson.mn.googlepages.com/tubebooster
Post by: comfortably_numb on August 19, 2008, 07:18:33 AM
Should be easy to design using a space charge tube, referencing that schematic.
Post by: vasko on August 19, 2008, 03:41:54 PM
Jimmy-H ,this got no bass,gain,treble contrtols...and how is this penthode working on 36 V???? Usually tubes use 300V...all bellow 100V is "fishy" to me
Quote from: Renegadrian on August 18, 2008, 07:19:01 PMGot ECC82??? BUILD A VALVY!!!  :icon_wink:
is this valvy?  http://www.beavisaudio.com/Projects/ValveCaster/MatsuminValveCaster.gif
same...9V ...no way this is gonna work
Post by: Renegadrian on August 19, 2008, 04:06:03 PM
GRRRRRRRRRRRRRRRR :icon_evil:
How'd you say it cannot work?!?!? Just try one!!!
You have to understand that tubes aren't only for those high voltages...12V can make quite a sound!!!
