DIY Stompboxes => Building your own stompbox => Topic started by: asatbluesboy on August 25, 2008, 01:40:40 PM
Title: Pedal drilling
Post by: asatbluesboy on August 25, 2008, 01:40:40 PM
I just want to share my joy with the world: last night I used a recently-bought stepped bit to drill an enclosure, and oh, boy, how my life changed. I won't say the brand I'm using or the store I got it from. I'm just saying: get one of those. It's not only a time saver, but actually makes drilling a more pleasurable experience - I have a scar on my right pulse from the bit-changing days.
Cheers!
-Gustavo
Title: Re: Pedal drilling
Post by: jacobyjd on August 25, 2008, 01:56:00 PM
I've used a stepped bit to drill enclosures in the past (not for pedals, but same idea), and they work great w/ a drill press...I've never used them w/ a hand drill before, but I'd figure it would be similar.
On a similar note, I read a suggestion to try a wood boring bit (like this: http://www.toolstation.com/images/library/stock/webbig/44945.jpg (http://www.toolstation.com/images/library/stock/webbig/44945.jpg)), and I found the results to be excellent. I used a 1/2" one to drill fro a 3pdt stomp switch, and it worked like a charm.
...only on aluminum though :)
Post by: cpnyc23 on August 25, 2008, 01:57:08 PM
Yep - that was one of my best purchases as well.  I highly recommend cleaning it well after each use.
-chris
Post by: morpha2 on August 25, 2008, 03:14:53 PM
Quote from: cpnyc23 on August 25, 2008, 01:57:08 PM
-chris
What's a good method?
Post by: asatbluesboy on August 26, 2008, 10:14:38 AM
Quote from: jacobyjd on August 25, 2008, 01:56:00 PM
I only have a hand drill, and it works like a charm. You've just gotta train a little so you can feel the steps. Punch-marking is a must, though. Any nail should do.
Post by: ayayay! on August 26, 2008, 10:27:43 AM
A good method to clean it is to spray a tiny bit of WD-40 on it and rub it with steel wool.  Don't rub hard though, some of those markers might disappear.  Or, WD-40, let it soak for a minute or two, then blow it off with a compressor.
Then spray it again when done (lightly) or apply a little 3-in-1 oil to it so the bit has a nice coat to prevent corrosion, and it helps the next time you cut too.  :)
