DIY Stompboxes => Building your own stompbox => Topic started by: ech0es on May 08, 2009, 09:16:11 AM
Title: how to wire a mono in / stereo out bypass
Post by: ech0es on May 08, 2009, 09:16:11 AM
If i only have a 3PDT and without a led, is it correct:
(http://img6.imageshack.us/img6/8839/3pdtstereo.jpg)
I want to build this thing:
http://www.loop-master.com/product_info.php?products_id=94
thanks a lot guys
Title: Re: how to wire a mono in / stereo out bypass
Post by: aziltz on May 08, 2009, 10:35:18 AM
that is effectively a Y-Splitter in off-mode.  not the best idea.  you might want to look into adding a buffer or two.
Post by: MikeH on May 08, 2009, 11:11:45 AM
What you've got there is probably the same thing as in the link, because they say it will work without power.  But yeah, just passively splitting the signal like that isn't the best way to do it.  You could improve on the design by buffering the outputs.  Of course if you're running a buffered pedal right afterward it doesn't matter.
Post by: nelson on May 08, 2009, 12:40:48 PM
You could wire it with an LED if you used RG's millenium bypass.
