DIY Stompboxes => Building your own stompbox => Topic started by: mantella on May 21, 2009, 09:34:00 PM
Title: really old easyvibe pcb layout
Post by: mantella on May 21, 2009, 09:34:00 PM
I have this pcb made, and managed to decipher the layout:
(http://www.adamwiens.com/images/ez-vibe-old.jpg)
I got the whole circuit put together. However, when I compare it to John's original schematic (http://www.hollis.co.uk/john/easyvibe.jpg) I notice that there are diodes missing next to the depth pot. I got the pedal to work, but it sounds more like a tremolo than a vibe sound. Would the missing IN914's be the issue?
Thanks.
Title: Re: really old easyvibe pcb layout
Post by: enquiryband on May 22, 2009, 11:27:12 AM
most vibratos aren't actually true vibrato. a real circuit vibrato that bends the sound is hard to do.
reading is your best friend. read all about this here. i came across it while trying to research my vintage amp. http://www.vibroworld.com/magnatone/vibrato.html (http://www.vibroworld.com/magnatone/vibrato.html)
Post by: RedHouse on May 22, 2009, 11:42:38 PM
Quote from: enquiryband on May 22, 2009, 11:27:12 AM
Dude, the Easyvibe is not really a "vibrato", it's a IC based version of an early phase shifter (ie; Univibe) but really much more like a 4-stage Phase-100
But as you said, reading truly is your best friend, you can read here on this firm many posts about the EasyVibe.
(search is also your best friend)
Post by: mantella on May 23, 2009, 10:22:18 AM
thanks guys, I actually realized I had read the scheme wrong. I see that on John's schematic he has the ldr's in a different place than the led's that are driving them. Once I figured that out, I could see where the other diodes should go. So I got the univibe sound I was looking for. I swear, sometimes it's good when things go wrong, because it forces me to really analyze the circuit. I end up understanding things far better than when I'm able to just slap the components on the boards and everything goes right the first time. Though, that's far less frustrating ;-)
I built the "newer" version of the easyvibe too (http://www.geofex.com/PCB_layouts/Layouts/easyvibe.pdf), but wanted to try this one out as well. No real difference, but the trimpot I used on this one seems to affect the sound much more dramatically than the other.
Thanks again.
