So the pedal is an EH Stereo Memory Man W/ Hazerai... The function I'm trying to change is the looping feature. Currently to record a loop you have to hold down on the switch during the whole duration of a loop. My goal is to make it work like a normal loop pedal and only have to hit the switch once to start the loop and another time to start the repeat. I've been told that I can do this by installing a simple on/off type switch and wire it to two of the lugs on the 3pdt footswitch... But the person didn't know which lugs and I don't understand how the switch works and have been unable to find information.
the loop/tap tempo footswitch its an SPDT momentary with only 2 of the lugs connected. Simply connect your switch to those two lugs.
(http://img39.imageshack.us/img39/8910/hazq.jpg)
keep in mind the stock switch won't operate unless your additional switch is 'off'. be careful! if you switch modes with the switch accidentally on it'll start recording a loop on you and your tap tempo won't work. would not be fun in a live situation!
You could use less switch, a SPST would do the 'work part'.
With either of the 'more switch than you need' [3pdt or dpdt] use one of the other pole/throw 'columns' to de/activate an LED indicator with current limiting resistor for the new' function.
