DIY Stompboxes => Building your own stompbox => Topic started by: jeremypb on December 31, 2009, 01:58:58 PM
Title: flashing led's
Post by: jeremypb on December 31, 2009, 01:58:58 PM
wondering if anyone knows a simple circuit that will cause 1 or more led's to flash when a note is played.
Title: Re: flashing led's
Post by: head_spaz on December 31, 2009, 02:36:58 PM
Look up LM3915 at National Semiconductor.
They are used for building VU meters mainly.
Post by: GibsonGM on December 31, 2009, 03:01:02 PM
Could just build an opamp circuit and set the quiescent gain at a threshold just a tad lower than the LED turn-on voltage.  That way, an input signal would light 'er up.  Pretty simple, depends on what you want to do with the flashy LED and how many you need....
Post by: mth5044 on December 31, 2009, 03:24:18 PM
You could try the first part of the Clari(not) schematic found on this forum.
Post by: jeremypb on December 31, 2009, 09:05:33 PM
thanks for the suggestions. i'll try some of those and let you know what works/doesn't
