DIY Stompboxes => Building your own stompbox => Topic started by: humptydumpty on January 14, 2010, 12:55:53 AM
Title: 3PDT Amp Footswitch Help?
Post by: humptydumpty on January 14, 2010, 12:55:53 AM
I have a diagram for a peavey valveking 100 footswitch, but was wondering if it could be downgraded to one switch with one LED, to notify which channel is on.
I will post the wiring diagram if it is needed.
Title: Re: 3PDT Amp Footswitch Help?
Post by: petemoore on January 14, 2010, 01:16:06 AM
 We like to make our wiring diagrams feel needed, they do so much for everyone.
 Otherwise it's 20 questions, questionable quality.
Post by: humptydumpty on January 14, 2010, 01:36:12 AM
Well here it is, sorry i didnt label it, but it goes like this from top to bottom (open-ended lines)
1. sleeve
2. ring
3. tip
(http://img44.imageshack.us/img44/1766/42557043.jpg)
Post by: humptydumpty on January 14, 2010, 02:16:56 AM
damnit, those circles are leds
Post by: duckpow on January 14, 2010, 03:56:13 AM
Maybe something like this?
(http://img687.imageshack.us/img687/5533/oneswitch.jpg)
...don't know if it will work... depends on how the amp is designed
Post by: metallo on January 14, 2010, 06:54:37 AM
If I understood your question correctly, you want to reduce a 2-function foot switch to a 1-function foot switch.
This can be done with a single SPST by removing the other part like so:
(http://img693.imageshack.us/img693/2190/crudswitchfixd42557043.jpg)
You can always treat yourself to a 3PDT, but a SPST is all you need.
If the wrong function is selected, change your tip/ring wiring.
If the wrong option is selected for the other function that you don't want on the switch, then play around with your stereo/mono jacks until you achieve what you want.
Post by: humptydumpty on January 14, 2010, 01:48:42 PM
no im trying to add both switches into one, so there is no need for two switches
Post by: humptydumpty on January 15, 2010, 01:08:23 AM
bump?
Post by: PRR on January 15, 2010, 08:38:23 PM
Two one-way switches offer FOUR possible settings:
off-off
off-on
on-off
on-on
There's no standard foot-switch to do that.
There used to be switching that worked like a motorcycle shifter. Each click ratchets into another gear. While bikes should not do a 4-1 shift easily (roAAAAAAARRRRRRR!sputt), that's often OK in 4-way audio selection, so the ratchet sweeps 1-2-3-4-1-2-3-4-1-2-3... However that was rarely a standard nor cheap part. The only "low price" version I can think of was the head-stepper on an 8-Track car tape player, and that would need re-thinking how the switching goes (probably 3 diodes).
Post by: humptydumpty on January 21, 2010, 11:56:41 PM
would this work, maybe?
(http://img96.imageshack.us/img96/9112/21312i.jpg)
