I was just wondering if anyone had come across any more Muff PCB tracer layouts, other then the Triangle V1
(http://i55.photobucket.com/albums/g146/icecreamterror/bmbck.gif)
Especially after any from the SOVTEK Muffs.
I traced this one from a gutshot of an older green russian, it would need to be sized properly I guess. Even at a glance I can tell I got the pad spacing on the jack inserts a bit out of whack.
(http://i26.photobucket.com/albums/c143/ringworm_1974/greenpcb.jpg)
I traced both IC versions, the 77 and 78 ones and kept the original layouts. I'll upload them later when i have time/find them.
do you mean this one?
http://www.aronnelson.com/gallery/main.php/v/Gila_Crisis/Big_Muff/Opamp_Big_Muff/ICBMPLayOut-1.jpg.html
ringworm, thats excellent! (do you happen to have a populated version?).
bumblebee look forward to seeing them.
Gila_Crisis thank for the link, much appreciated.
Quote from: Gila_Crisis on February 24, 2010, 11:03:48 AM
Yeah that ones mine, plus I have another for the 78 vbersion with tone bypass. i cvhecked it and I havent actually finished the PCB...i mean it is finished but the traces arent wide enough so I'll get to it.
I'll upload both to my gallery (which is empty)
Here's an updated/edited version of the 1st issue green Sovtek PCB. Jack spacing is perfect. I put all the original markings (in cyrillic) on it so you can just use it as a drop in replacement if need be. You will still need to drill the three mounting holes so use your old PCB to mark for them.
K is collector/B is Base/3 is Emitter. I will make a parts layout for it at a latter date.
i didn't measure the PCB size but the distance from the center of one jack to the other is 6.9mm, that will help you if it gets messed up in size on some PC's.
(EDIT:Refresh for new image if you have already looked at this, I uploaded the wrong one)
(http://i1016.photobucket.com/albums/af286/fenderamerica/Big%20Muff/PNP1STGSBMPCB.png?t=1267059093)
NOTE: this PCB cannot be used in black Sovteks without editing the jacks spacing as its too wide.
Excellent stuff bumblebee!
Thanks man! :icon_mrgreen:
CORRECTION, I made a typo before! it should be 6.9CM between jack center inserts, not 6.9mm.
I took one of my 1st issue green Sovteks apart and measured the PCB, its 9.5cmx9.5cm (95mmx95mm)and the space between the center of the jack pads to the center of the other jack pads is 7cm (70mm) but when the jacks are in its 6.9cm (69mm) so either will fit anyways.
I will make it into a DIY project in the next day or so, so people with stuffed PCBs (from modding etc as the early Russian PCB pads lift very easily) can just make a drop in replacement. In the Project I'll resize the border of the PCB to be exactly 95x95mm as well, save you guys having to do it.
Well once you done the SOVTEK "GREEN RUSSIAN" BIG MUFF π - VERSION 7 Revision C to scale, it wont be that difficult to adjust it to make drop in replacements PCB transfers for:
"RED ARMY"
"GRAY AND GOLD" VERSION 7
"CIVIL WAR" VERSION 7 A
"CIVIL WAR" VERSION 7 B
They all use different PCB layouts so if you wana be correct (like I would LOL) it wont do. But you can build any muff you like on it....
You could even adjust if for the small box black version if you wanted.
Quote from: peps1 on February 24, 2010, 02:03:01 PM
I never got round to it but I see bumblebee is on the case.
Nice one.
Quote from: bumblebee on February 25, 2010, 04:19:39 AM
The 4 i listed are remarkably close to the 7/c muff pcb, defiantly not the same but the tracers could be adjusted....just laid your PCB over them in photoshop and the scales are bang on (with the exception of the jack positioning) would just a small editing job to get the authentic layouts for the earlier Sovtecs. (will give it a go when yours is done)
Yeah I have to redo mine, that one I posted is no good. the jacks line up but the traces and are all out of wack in relation to the board size (95x95mm).
So I'll scale the traces to a photo of that PCB then once that;s done I'll fix the Jacks...again. This didnt even occur to me, I first adjusted the jacks and just overlooked confirming the scale of the traces.
In a 95x95mm PCB with this scale traces I posted there's way too much board left so it just shows how much I misjudged it.
I'll do it tonight anyways and post it tomorrow. Also a populated layout too.
I'm still not exactly sure what the problem is, either the traces are all out of proportion or its something I did. Anyways, i'll make it workable ... :icon_mrgreen:
I'll also finish my 77 IC layout and post all three layouts when I'm done.
I have been in the process of makeing one for the ramshead muff too, I have done a rough circuit trace,it just need cleaning up.
I like the idea of having "drop in replacements" of all these original layouts for the big muff. Everyone wants to go small all the time, but I like my pedals BIG like the cast sovteks and american muffs. I dont like MXR size pedal much and always try to avoid using them, i like to use at least a 1590BB.
Quote from: bumblebee on February 25, 2010, 06:02:38 PM
Me too, and with the added element of all the people who like to make pedals with original era carbon composition resistors & transistors....giving them a authentic PCB can only be a good thing!
Good luck, and make it work ;)
I will! I'm a Big Muff fanatic, I live Big Muffs. :icon_lol:
:icon_mrgreen:
Any update on a version 0f the scaled GREEN RUSSIAN VERSION 7?
Keen to etch some up ;D
Sorry I havent finished one yet, I been busy. I' will get it doen unless someone beats me to it.
Reworked the old "TRIANGLE" BIG MUFF π - VERSION 1 1969-1973 that's been floating about.
Old
(http://i55.photobucket.com/albums/g146/icecreamterror/bmbck-1.png)
New
(http://i55.photobucket.com/albums/g146/icecreamterror/muff-smooth-1.png)
Reworked the old THE OP-AMP BIG MUFF π - VERSION 4 Circa 1978 (EH3003B)
Old
(http://i55.photobucket.com/albums/g146/icecreamterror/ICBMPLayOut-1.png)
New
(http://i55.photobucket.com/albums/g146/icecreamterror/ICBM.png)
(http://i55.photobucket.com/albums/g146/icecreamterror/firstopampboard.jpg)
There is an error on the version 4 Big Muff Op-amp PCB layout. It's missing the ground connection from pin 4 on the RC4558 IC chip. The circuit will not wok without this connection. There should be a solder trace going from pin 4 to the .01uf capacitor near the chip. This can be verified when you compare the PCB trace to a photo of an EH3003B circuit board. I've circled the spot in the photo below:
(http://img709.imageshack.us/img709/2341/eh3003b.jpg)
a jumper will do fine there?
Yes, a jumper wire will work fine here. That's all I was using when I breadboarded my test build. Worked great once I made that ground connection.
Many thanks dude! Worked fine!!!
A hammond DD size will fit? This is a huge pcb.
What a wonderful post! May I plead for a Ram's head to scale circuit board template!? :icon_mrgreen: Please! Please!
Quote from: killerkev on June 24, 2011, 11:30:52 PM
RAMS HEAD
(http://i55.photobucket.com/albums/g146/icecreamterror/RAM-BIG-MUFF2.png)
Still need some flatbed scans of the russian boards, and measurements........so if you got a Russian Green, RED ARMY or CIVIL WAR and are willing t scan and measure the board give me a shout! :icon_biggrin:
DOWNLOAD SCALED RAMS HEAD FROM HERE > http://pdfcast.org/pdf/rams-head-big-muff-pcb
(IC BMP also updated to include that missing track.....but you may have to refresh your browser before grabbing it)
Thanks peps1!!!!!!!!!
Hi guys,
For the RAMS HEAD version...any equivalent can replace for :
Transistor FS 36999
Diode IN914
Thank you in advance
Quote from: bumblebee on February 24, 2010, 07:41:31 PM
hey Bumblebee, any updates on this? :)
(https://i.postimg.cc/67bLrGLc/Russian100x90.png) (https://postimg.cc/67bLrGLc)
(https://i.postimg.cc/MnWygY9t/Triangle78x75.png) (https://postimg.cc/MnWygY9t)
Here are my russian (100x99mm) and triangle version (78x75)
Same problem measure pot and jack ;D
Quote from: zbt on October 14, 2023, 04:00:30 AM(https://i.postimg.cc/67bLrGLc/Russian100x90.png) (https://postimg.cc/67bLrGLc)
Thanks, but the size of your russian layout is wrong. It's a pcb of the later bubble font and black russian big muffs. But the size isn't correct. The actual pcb is way smaller and jack spacing too. Can you update it to correct the size?
EDIT: I guess I will do it anyway so I'll post it here after I scaled it to the correct size.
EDIT II: I didn't etch it yet, but I compared it to my OG bubble font and black russian pcb and those are the right sizes.
Height: 8,9 cm
Width: 9,87 cm
(Those sizes are for png and do not represent the actual size of the original pcb). Scale it down to those sizes and it will fit a black russian or later bubble fonts.
the version
http://www.kitrae.net/music/V7_3rd_edition_pcb.jpg (http://www.kitrae.net/music/V7_3rd_edition_pcb.jpg)
may be if I know the distance between audio jack
here is another attempt
http://www.kitrae.net/music/Green_T_Muff_Circuit_trace.jpg (http://www.kitrae.net/music/Green_T_Muff_Circuit_trace.jpg)
(https://i.postimg.cc/MX7SGG6c/Green-Russian-110x103.png) (https://postimg.cc/MX7SGG6c)
(https://i.postimg.cc/Z9QdsHjK/BM-98-7x89.png) (https://postimg.cc/Z9QdsHjK)
new size, still audio jack not align well
