DIY Stompboxes => Building your own stompbox => Pictures => Topic started by: therecordingart on March 17, 2010, 09:09:42 AM
Title: A Firefly is born....
Post by: therecordingart on March 17, 2010, 09:09:42 AM
I'm only unhappy about three aspects of this build...
-My bit that drilled the pilot holes for the tubes to pass through must've wandered leaving them off center. I can't put a shield over the middle tube (I'll need to widen the hole).
-Mouser has a backorder on the switch used for "Boost" so I had to sub a Rat Shack switch
-I lost one of the standoffs for the PCB which leaves an open hole in the chassis
But this thing sounds great! I work at a commercial recording studio part time and will have sound clips soon...
(http://i235.photobucket.com/albums/ee228/therecordingart/IMG_3322.jpg)
Title: Re: A Firefly is born....
Post by: John Lyons on March 17, 2010, 12:59:49 PM
Cool!
No need to shield the tube.
For audio applications it doesn't do much if anything.
Post by: DougH on March 17, 2010, 01:04:27 PM
Looks nice! Love the graphic!
Post by: jacobyjd on March 17, 2010, 01:09:27 PM
LOVE it. I'm so dying to build an amp--too many repair projects sitting around :(
Post by: therecordingart on March 17, 2010, 07:27:19 PM
Thank you all.
The graphic I got from "Googling" firefly and looked through some clipart. This was my first time using waterslide decals and building tube gear. Now I'm not so intimidated by either. The sound that comes out of this thing really exceeded my expectations...especially running it direct. I'm using a Behringer GI-100 with a 100w/8 ohm dummy load that I got from Parts Express. The cab emulation on the Behringer unit isn't bad at all.
I think I have a new addiction....tubes!
Post by: punkin on March 19, 2010, 05:02:39 PM
Snatch up the PCB while you can...they're going out of production from what I'm hearing.
Post by: therecordingart on March 19, 2010, 05:04:19 PM
Quote from: punkin on March 19, 2010, 05:02:39 PM
The upside is that John made the .pcb file available if you choose to mod the layout or order direct from Express PCB. I'm sure it'd be pretty expensive ordering in single quantities though.
Post by: John Lyons on March 19, 2010, 05:36:06 PM
Many have been made without the PCB. Mine included. It's a simple amp to build.
Post by: punkin on March 20, 2010, 12:12:09 PM
Yep...that's how I built mine...mostly because I wanted to make some mods...added a switchable tone stack, line out and a master volume control. Very rewarding build and a great sounding little amplifier. I also went with a torroidal power transformer...cheaper and no worries about placement. I think everyone should give this build a try.
Post by: Brymus on March 22, 2010, 01:06:34 AM
Yeah thats nice,I so want to build one.
What toriodal did you use,I see a hammond in the pics?
Post by: chrisrbr on April 29, 2010, 06:46:41 PM
Nice Job.
I built one of these a few years ago into a Champ cab--love it.  Use it for most of my practicing at home.  Don't need to unpack my gigging amp.
