DIY Stompboxes => Building your own stompbox => Topic started by: LucifersTrip on August 18, 2010, 03:46:48 PM
Title: Anyone use VTL5C2 instead of VTL5C3 in Uglyface?
Post by: LucifersTrip on August 18, 2010, 03:46:48 PM
I have VTL5C2, so thought I ask before I order the VTL5C3's for the optoisolator/Vactrol...
What other models worked as well as the original?
thanx
(http://www.jiggawoo.eclipse.co.uk/guitarhq/Circuitsnippets/uglyface.gif)
Title: Re: Anyone use VTL5C2 instead of VTL5C3 in Uglyface?
Post by: MikeH on August 18, 2010, 05:54:32 PM
Look up the data sheets; if they just have different turn-on/turn-off times you'll probably be fine, but if they have vastly different resistances, it won't work right.  My guess is that it would work fine.
Post by: soggybag on August 18, 2010, 07:19:39 PM
You can use just about anything as the LED/LDR in the Ugly Face. Even, roll your own by shrink wrapping discreet LED and LDR together.
The envelope may sound a little different depending on the part. I wouldn't worry about the differences too much the effect will still work.
Post by: LucifersTrip on August 18, 2010, 11:22:47 PM
Quote from: MikeH on August 18, 2010, 05:54:32 PM
Thanx much for the info. Unfortunately, I'm too much of a novice to tell how large of a difference would make a significant change in the Uglyface's sound...though I'll definitely do some more research.
(http://www.demonsdisks.com/pics/vt500.jpg)
Post by: LucifersTrip on August 18, 2010, 11:25:29 PM
Quote from: soggybag on August 18, 2010, 07:19:39 PM
I was thinking about doing that since I used similar things in circuit bending...but I was trying to start with something close to the original, then possibly mod...
thanx
Post by: soggybag on August 19, 2010, 01:26:45 AM
I wouldn't worry about it too much. The Ugly Face will work with just about every LED/LDR combo. If you have a selection of LDRs to choose from test them all. If you have VTL5x just use it. I bet it will work fine.
