DIY Stompboxes => Building your own stompbox => Topic started by: Jhouse on October 01, 2010, 05:13:46 PM
Title: Distortion circuit in a guitar.
Post by: Jhouse on October 01, 2010, 05:13:46 PM
If I wanted to put say a circuit for any type of distortion inside of a guitar, could I set it up so it can run on both a battery or phantom power?
Title: Re: Distortion circuit in a guitar.
Post by: Govmnt_Lacky on October 01, 2010, 05:24:17 PM
Quote from: Jhouse on October 01, 2010, 05:13:46 PM
or phantom power?
Post by: Jhouse on October 01, 2010, 05:32:37 PM
Phantom power is a means of distributing a DC current through audio cables to provide power for microphones and other equipment. It's usually in balanced cable and direct boxes can give the option for it too.
Post by: amptramp on October 01, 2010, 08:07:32 PM
A lot of industrial processing equipment use 4 - 20 mA sensing circuits where the output is modulated on the power leads as a current.  Instead of a voltage output, you have a current output which is converted to voltage very simply with a resistor.  Since this voltage modulates the supply voltage, the circuit must be designed to work over a range of input voltages.  With battery operation, the output would still be a current.
Post by: ashcat_lt on October 01, 2010, 08:10:47 PM
Yes.  Other people do it and sell it. Requires a TRS jack in the guitar and a phantom supply box with some short protection for when the cable is being plugged and unplugged.  The positive of the phantom on the ring, negative on the sleeve.
If you mean being able to switch back and forth, you'll need a shorted battery clip to replace the battery, or put in an spdt.
