Hey all,
I've been looking for vertical PCB-mount pots that can be pressed (momentary switch). Kind of like this:
http://ca.mouser.com/Search/ProductDetail.aspx?R=RK09L1140A5Pvirtualkey68800000virtualkey688-RK09L1140A5P
But with the button. I've seen loads of rotary encoders of similar shape and size with buttons but never pots! I've spent hours looking on mouser and google, no dice.
Any ideas?
Check these out:
http://www.alps.com/WebObjects/catalog.woa/E/PDF/Potentiometer/MetalShaft/RK097/RK097.PDF
Another Alps line. Not sure if Mouser carries the one you want, but if not at least you can figure out the part number you need.
