DIY Stompboxes => Building your own stompbox => Topic started by: rosscocean on April 28, 2011, 07:05:41 AM
Title: LM567 ring modulator circuit
Post by: rosscocean on April 28, 2011, 07:05:41 AM
I've had a go at a ring mod type circuit from beavis audio http://www.beavisaudio.com/bboard/projects/bbp_567Mod_Rev_1_1.pdf
Is the circuit supposed to have the constant drone? and is there a way to get rid of it? I've tried searching on google and stuff and I can't find anything.
Thanks in advance
Ross
Title: Re: LM567 ring modulator circuit
Post by: anchovie on April 28, 2011, 08:20:06 AM
The chip has an internal oscillator that you can't shut off. It's supposedly quieter if you use the LMC567.
The complicated way to get rid of the drone completely would be to have an envelope detector in front of the chip that controls a gate on the output.
Post by: digi2t on April 28, 2011, 08:32:48 AM
I vero'd and built this; http://www.forrestwhitesides.com/node/97 (http://www.forrestwhitesides.com/node/97) . The Logan 5 is an LM567 based pseudo-ringmodulator.
I actually combined it with an Escobedo Digital Octave Fuzz, and it works well. I don't get any droning at all. Here is a clip http://www.soundclick.com/player/single_player.cfm?q=hi&songID=10490290 (http://www.soundclick.com/player/single_player.cfm?q=hi&songID=10490290), the section from :50 to 1:15 is the DOF running through the Logan 5.
Of course, keeping any oscillating circuit quiet during bypass requires grounding the input. That said, mine is very quiet.
Post by: rosscocean on April 28, 2011, 05:04:04 PM
Thanks, I'll give that a go!
Ross
