DIY Stompboxes => Building your own stompbox => Topic started by: agoldoor on July 18, 2011, 04:43:57 PM
Title: ? about vero layout
Post by: agoldoor on July 18, 2011, 04:43:57 PM
Hey,
Big question about the following layout below:
http://i50.photobucket.com/albums/f326/psychobilly80/Layouts/render-1.gif
On this layout, I see the three terminals of the trimmer connected to the vero. In almost all cases I've come across before, two of the terminals of the trimpot are put together, not with all three connected to the vero.
Can someone please tell me what to do here? I'm pretty confused.
Title: Re: ? about vero layout
Post by: twabelljr on July 18, 2011, 07:08:55 PM
Can you see the cut-out under R4? The third terminal is soldered in place just for sturdiness it looks like. It does not connect to anything. The variable resistance is set with the top pin and the bottom left pin. I believe the top one is pin 2 and the bottom left pin 3. (or 1)
Post by: EATyourGuitar on July 19, 2011, 09:14:23 AM
exactly, its not connected. you can also get 2 leg trimmers if it is cheaper and saves space.
