DIY Stompboxes => Building your own stompbox => Topic started by: bsmcc2010 on August 25, 2011, 06:54:02 AM
Title: dynacomp mod
Post by: bsmcc2010 on August 25, 2011, 06:54:02 AM
Hey guys,
So i had this idea of building a dynacomp like compressor but adding in a tone and clean blend controls. I'd make the tone circuit switchable so i could take it out of the signal path all together if i wanted.
I've found schematics for the general dynacomp and for the tone and blend circuits i'd build, but the only thing is where to put them in the overall circuit. They need to go inbetween the sustain and level controls of the dynacomp circuit, but the trouble is i'm not sure where the sustain control ends and the level control begins. If i knew this i could easily place the tone and blend circuits before the level control.
Here is a wiring diagram of the dynacomp and a schematic. If anyone can tell me where to put my added circuits that would be amazing!
(http://img824.imageshack.us/img824/8100/basiccompressor.jpg) (http://imageshack.us/photo/my-images/824/basiccompressor.jpg/)
(http://img801.imageshack.us/img801/9214/basiccompschematic.jpg) (http://imageshack.us/photo/my-images/801/basiccompschematic.jpg/)
Title: Re: dynacomp mod
Post by: petemoore on August 25, 2011, 07:13:14 AM
  Determine whether the load of the TC would require an impedance 'rework...
  The TC could be placed as replacment for the 10k, just before the volume pot.
Post by: bsmcc2010 on August 25, 2011, 09:43:47 AM
Thanks petemoore.
So are you suggesting just replacing the 10k with the tone pot and no other circuitry?
If i did that would i also put my blend pot between the tone and volume pots?
Post by: guitylerham on August 25, 2011, 12:17:24 PM
I am going to do the same thing as you!
I want to use the second TC in this link (the one he suggests best for compressors):
http://www.muzique.com/lab/swtc.htm
and put it in the design for the DynaComp with Jangle Switch and Blend Knob here:
http://www.aronnelson.com/gallery/main.php/v/ibodog/other/dynacomp+with+clean+blend+vero+verified+v1_1.gif.html
From what I can tell, you can just put the TC in line with C23 and the Volume Pot. Does this make sense? I've yet to build and verify these mods together.
Post by: Nasse on August 25, 2011, 02:01:21 PM
I have old eh black finger (741/3080) version and it has big muff tone control at the end, bit noisy and distorts but used to like the tone
Post by: bsmcc2010 on August 25, 2011, 02:49:01 PM
thanks guitylerham.
so are the red squares on this board where you cut the hole out? and is it just a plain pcb with holes punched in it?
Also, i can't seem to see a switch on there? i'd want a 3pdt switch with LED
Post by: deadastronaut on August 25, 2011, 03:16:32 PM
its vero board/strip board...its copper clad in strips with holes drilled already, red markers are for the cuts ..
you will be able to add a 3pdt with led too ok...... ;)
Post by: bsmcc2010 on August 26, 2011, 09:07:28 AM
for some reason i can't access this page anymore?
Post by: deadastronaut on August 26, 2011, 09:08:36 AM
hmmm...me too... ???
Post by: bsmcc2010 on August 26, 2011, 09:21:18 AM
Thats really annoying...that was by far the best and easiest schematic/wiring diagram i'd found. All i needed to do was add the tone control and the 3pdt switch into it, which isn't hard! :(
Post by: deadastronaut on August 26, 2011, 09:32:05 AM
google!.images... ;)
http://www.sabrotone.com/?attachment_id=1018
Post by: bsmcc2010 on August 26, 2011, 09:37:21 AM
that's not it  :-\
that looks like just a jangle box to me
Post by: deadastronaut on August 26, 2011, 09:40:15 AM
oh ok... ::)
Post by: bsmcc2010 on August 26, 2011, 09:43:12 AM
i think it's been deleted from the site  :-[
Post by: bsmcc2010 on August 27, 2011, 06:40:38 AM
still can't seem to find the diagram that guitylerham linked us to anymore :/ why help?
Post by: alfafalfa on August 27, 2011, 10:09:09 AM
I think you might mean this one ?
http://img694.imageshack.us/img694/181/dynacompwithcleanblendv.gif (http://img694.imageshack.us/img694/181/dynacompwithcleanblendv.gif)
Post by: bsmcc2010 on August 27, 2011, 10:33:10 AM
That's exactly the on! only that is the un-verified version...looks the same to me though
thanks!
Post by: bsmcc2010 on August 27, 2011, 03:10:36 PM
ah man, just realised that that's not the same as the verified one...which music mean that it doesn't work? :S
Post by: guitylerham on August 27, 2011, 07:04:54 PM
Ah! Forgot about this thread! I'm away from home at the moment but I'll be sure to upload the layout from my original post. I just happened to save it to my computer before it was removed!! give me a day or two, promise!
Post by: bsmcc2010 on August 28, 2011, 06:26:42 AM
amazing, i was hoping you'd say that :)
cheers man
Post by: guitylerham on August 30, 2011, 12:30:45 AM
Ok guys, sorry I've been away so long. Here is the original DynaComp link I posted with the jangle switch and blend knob. It appears to be verified.
http://www.flickr.com/photos/tylerh5/6095119723/
Post by: bsmcc2010 on August 30, 2011, 01:41:01 PM
thank you so much,
thought i'd never see it again :')
