DIY Stompboxes => Building your own stompbox => Topic started by: StephenGiles on December 23, 2011, 04:07:38 PM
Title: Steve Morse delayed (?) reverb effect
Post by: StephenGiles on December 23, 2011, 04:07:38 PM
I've been listening to Steve's guitar antics, and one of his tricks seems to involve reverb braking in during a single sustained note after a fast run. So could that be a CV extracted from the decay of the single note which is applied to a VCA controlling the reverb output perhaps? Or it could just be a volume pedal :icon_question: :icon_question:
It could also be a pluck follower in reverse, ie the slower you play, the higher the CV - any thoughts?
Title: Re: Steve Morse delayed (?) reverb effect
Post by: deepMago! on December 23, 2011, 05:49:35 PM
I've seen time ago a video showing Morse's rig time ago. He uses volume pedals before the effects and simply open them to add effects. No switch system, only a volume for delay, one for reverb and one for gain level if I remember well. One amp for dry signal and one for effects.
Post by: StephenGiles on December 24, 2011, 05:36:47 AM
Thanks - he's up there with the likes of Jeff Beck to my ears!!
Post by: pinkjimiphoton on December 24, 2011, 12:17:44 PM
when i met hom last year, he was using two half stacks, and a tc nova delay in stereo with volume pedals. to get the effect, he'd just swell into the echo, coming from the second amp.
Post by: StephenGiles on December 24, 2011, 12:29:53 PM
How would you do this electronically?
Post by: pinkjimiphoton on December 24, 2011, 01:28:56 PM
beats me. he just turns up the volume pedal feeding the input of the echo with a lotta repeats.
Post by: Taylor on December 24, 2011, 11:49:08 PM
Many commercial delays/reverbs have the "ducking" feature, which is where the dynamic envelope controls either feedback or effect mix. If you wanted to build it, it would just be a matter of taking the envelope section from an optical compressor and putting the optocoupler in parallel with a delay feedback or level control.
Post by: oliphaunt on December 26, 2011, 01:13:02 PM
A ducking delay or reverb is my suggestion also.
Post by: StephenGiles on December 27, 2011, 05:13:14 AM
Yes but how would you configure a "slow playing detector"? Fast flurries of notes - no reverb, single sustained notes - plenty of reverb, echo or whatever. That would be the clever bit!
Post by: Taylor on December 27, 2011, 08:02:04 AM
Unless you play with a heavily compressed signal, IME just heavier filtering on the rectified signal creating the envelope will do it, since a bunch of note attacks will average to a higher DC level than a sustaining note tail. I have done this digitally, but the concept is the same in analog.
Post by: petemoore on December 27, 2011, 08:22:51 AM
  It'd seem pretty easy to do by throwing Photocells in the mix section, once the envelope detector to brighten LED's, and reverse the LED brightening to dimming effect by using a transistor inverter, to dim any LED's where you want inverted signal-to-LDR effect...  's figured out...
  Then just use LDR's to attenuate the reverb tank signal output, perhaps boost the clean mix [using LDR's to control gain] to fill in the loss [or more].
   Use light blockers or switch to do the sweeping honors, [and/or] trim LDR's with R's as needed.
