Where do you guys buy your perfboard? Where is the best deal? Im in the U.S. btw
You should probably shop around and see for yourself. Occasionally you'll come across a steal on amazon or ebay, but for consistently cheap parts (including perfboard as far as I've seen) I recommend tayda (http://www.taydaelectronics.com/). They have perf and strip board and from what I've heard it's pretty solid.
Tayda is great. I buy almost everything there. Their perf and vero is very good and cheaper than anywhere else I've seen.
I've been buying form this guy on eBay for a while:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320536845485&ssPageName=ADME:L:OC:US:1123
it's over 3 times larger than the perf on Tayda and much less expensive per square mm (130mm x 250mm = 32500mm @ $3.99 vs 142mm x 74m = 10508mm @ $2.30) ...you even can offer a little lower than $3.99
the large size also lets you chop it into many different sizes/shapes without waste
Quote from: LucifersTrip on February 29, 2012, 04:00:12 PM
(http://i492.photobucket.com/albums/rr283/DarkShadower/wrong-1.png)
Quote from: DavenPaget on February 29, 2012, 04:46:03 PM
Wrong
(http://i832.photobucket.com/albums/zz249/Perrow_MLP/Random/protoboard.png)
Quote from: Perrow on February 29, 2012, 05:03:32 PM
Wrong
Yeah ... 3 cents DC offset ...
Bad Poker Face
Both wrong, and my shipping guess was a little off, too....you are forgetting that Tayda adds shipping....of course, if you buy more, the shipping will decrease per item, but even if you buy a few, it'll still be more expensive...and you also do not have the flexibility of being able to cut a large piece into various shapes and sizes without waste.
130mm x 250mm = 32500mm @ $3.99 vs 142mm x 74m = 10508mm @ $2.14
(http://www.luciferstrip.com/fuzz/tayda-pcb.jpg)
(http://www.luciferstrip.com/fuzz/tayday-fail.jpg)
Don't consider it expensive though , i buy most of my stuff there on tayda , if you aren't looking at my order list on E14
Buying from BusBoard Proto Systems (http://www.busboard.us/) won't save you any money, but they make high quality products, and their boards are really convenient for prototypes and one-offs. Highly recommended if you're a breadboarder. They have a number of different boards. Here's an example of 3:
(http://ecx.images-amazon.com/images/I/51-t2%2BOfVAL._SL500_AA300_.jpg) (http://ecx.images-amazon.com/images/I/615sE2U%2BO5L.jpg) (http://ecx.images-amazon.com/images/I/614vP9rojkL.jpg)
If you're a strip-boarder, buy them from Aron and support the forum. :)
