I have some 2n2369s, which I'm guessing had the usable hfe ones removed as they run from 19 to 37. Anyway, they cost me nothing.
They look pretty, with gold legs, but are they any use beyond ornaments? Could I darlington them?
Quote from: Kesh on August 21, 2012, 07:17:56 PM
yes...or use bc or be as diodes
(http://electricly.com/wp-content/uploads/2010/05/An-NPN-darlington-pair.png)
there's definitely some circuits that use very low hfe silicon, but I think I only have schematics for low gain ge
you can try this type of Fuzz Face variant, with the output right off the collector:
http://www.luciferstrip.com/fuzz/fuzzface-fy2-mod-variable.jpg
remember, use a small vol pot and Q2C voltage is < 4.5v
Thanks. I was also thinking of using them as clipping diodes, but can I expect anything different from regular Si diodes in terms of clipping shape?
I had a vague idea to try and design some three stage version of the two stage fuzz face with them.
Pls see my notes:
https://www.smallbearelec.com/HowTos/GeDarlingtons/GeDarlingtonPairs.htm
I have done many hybrid germanium-silicon darlington pairs. It is literally a way to make silk purses out of sows' ears.
You can also make a percolator with an Si in Q1 instead of Germanium. Use silicon diodes too to keep the output up and costs down. :)
Quote from: midwayfair on August 21, 2012, 09:04:47 PM
Doesn't the harmonic percolator use a pnp transistor for Q1?
Quote from: smallbearelec on August 21, 2012, 08:48:19 PM
Pls see my notes:
This is great, thanks.
Low gain can have the same output as high gain, just takes a larger input signal to get there. You can probably use that as Q3 of a 3 transistor overdrive like the Vulcan. Any schematic with a large voltage divider before a transistor- substitute no divider plus your transistor.
CHAD
Quote from: seedlings on August 22, 2012, 09:02:17 AM
Roughly, gain is the increase from input to output, so is defined as being independent of the input level.
Quote from: Kesh on August 22, 2012, 10:01:57 AM
Gain is the
ratio of output to input.
One circuit has a gain of 100 with a 9V power supply so it takes .09V input to get 9V output.
Another circuit has a gain of 20 with a 9V power supply so it takes .45V input to get 9V output.
Both can give you 9V output.
CHAD
Yes, we all know that. Not quite sure what you're trying to add here.
The voltage gain of a transistor stage is not the same as hfe current gain, and is only tenuously related to it
Quote from: Kesh on August 22, 2012, 12:59:53 PM
Admittedly, I'm not knowledgeable enough to help in anything beyond generalities. My apologies. :icon_redface:
I had been reading this thread http://www.diystompboxes.com/smfforum/index.php?topic=94883.msg820126#msg820126 and thought (perhaps mistakenly) that your low hfe transistors might still be usable in the last stage of an overdrive without adding much gain, just flavor. At the end of a vulcan-type overdrive the voltages are already large from the previous stage. Perhaps too simple and obvious a suggestion, but it's all I had to offer.
CHAD
