GGG Dim LED when bypassed
Started by avt, February 25, 2019, 01:08:49 PM
avt
Hello, I'm having a wierd issue, I just built the ITS8 with not mods or clipper switch, and it appears to be working fine, but when the battery is in and I plug into the input jack, the LED glows dim.  Then when you turn on the switch it comes on with the normal brightness as it should.  I traced all the wires and resoldered my input jack, I checked the board and it all looks good.  I don't know where I went wrong.  Any help would be appreciated.  Aaron
Kevin Mitchell
Are you sure your switch is wired to ground for the LED? It shouldn't be lit at all when bypassed unless you have a faulty switch.
My apartment looks like an imploded RadioShack.
avt
hey Mark, thanks, yeah I wired it exactly like the diagram, checked it over and over too.
Kevin Mitchell
Quote from: avt on February 25, 2019, 03:29:31 PM
hey Mark
Check again. Check if your switch is faulty. If the switch is okay the LED wouldn't have a ground connection when bypassed and shouldn't be lit at all. Maybe you have some wires touching that shouldn't be.
Test the voltage of the power supply. See if it changes when the switch is engaged. You might have a short somewhere and not realize it.
avt
Gotcha, I'll give it a shot this evening and let you know.  Thanks.
patrick398
I had this problem recently, i'd reversed the board ground wire and the led ground wire on the switch, easily done
avt
Hey Mark, I changed the switch and it seemed to work.  Thanks.
Patrick, meet Kevin.
Kevin, meet Patrick.
pinkjimiphoton
Slava Ukraini!
~Jack Darr
