Building the Meat Sphere
Started by Taylor, July 27, 2011, 03:39:06 PM
idy
10.5k should not change things. That is an odd value though... Is that by color code or measuring? I guess they do make those....
telebiker
I have a bag of these 10.5k, so probably I soldered them instead of 10k since I don't have 10k...
telebiker
So I found some 10k resistors and replaced these which should be 10k, and I have the same results. Will get some LM358 and share results.
telebiker
Quote from: telebiker on January 27, 2021, 09:12:41 PM
Looks like LM358 fixed the issue, thanks for the help! The envelope appeared.
Now having issues with bypass wiring, probably I did something wrong, but instead of effect there is pretty loud noise when the effect is engaged.
idy
Congratulations on your functioning meatsphere.
Do you know how your bypass scheme is supposed to work?
telebiker
Quote from: idy on March 09, 2021, 08:17:46 PM
I'm using bypass scheme from the build doc and it is pretty straightforward.
The only thing which confuses me, in the build doc GND connection from power supply is not indicated as connected to the common ground. I also haven't wired a loop until I have working bypass.
idy
The Doc I see shows the DC jack going right to the board (both wires) and then tells you to ground all the jacks.
I attach them all to a lock washer (internal tooth, an extra from a foot switch) and add a jumper to the DC jack ground, and put this around there DC jack.
The jacks must be attached to the same ground as the circuit!
telebiker
For some reason my LED wiring was wrong. I decided to use PCB slot for the LED and it worked finally. Will post some pictures once it is boxed.
Thanks again, Idy, I own you a beer :)
idy
Wacka wacka. Hope you love it and use it.
I am big on adding a switch and buffer so you can blend in either send or return.... mixing a filtered fuzz with straight signal is bit of oil and water...mixing filtered fuzz with straight fuzz is phasey magic.
My next ambition is to add a phase switch to play with this blending... HP and LP are inverted.
telebiker
Quote from: idy on March 10, 2021, 08:08:57 PM
BTW, is there schematics for these mods? :)
Tried Meat Sphere with the Fuzz in the loop and it's so cool.
idy
No schematic but you can find simple strip board layouts for buffers (I used and IC, but BJT and FET work).
http://tagboardeffects.blogspot.com/2014/08/buffers.html
You pull the #1 terminal of the blend pot out of the board and attach it to the center of a SPDT switch. Wire the buffer input to the "return" jack and the output to one terminal of the switch and the other terminal to the hole you pulled the pot terminal out of.
The phase mod: (unverified) You use a buffer that also has a phase reverse switch. These are also out there on strip board.
idy
The buffer with inverter would have to be after the switch...so it would invert the non-filtered signal from either send or return. Again, haven't tried it.
rectifierfx
Quote from: skarkowtsky on May 20, 2017, 03:05:11 PM
Hi everyone,
I'm new to the boards. I joined after discovering musicpcb.com and the Meat Sphere. I've read this thread, and am excited to build my own! I'm a graphic designer by profession, so I enjoyed identically recreating the Lovetone Meatball pedal interface this morning. I used an overhead photo of the original pedal as an overlay, tracked down the typeface and got to work creating the vector art.
My template is designed for the pedal enclosure sold on eBay that closely resembles the original (I'm not associated with the seller). I plan to have the template cut into a vinyl to use as a spray stencil directly onto the pedal surface.
Below is a jpg preview. Awaiting my pedal enclosure so I confirm the specs before I can share. I'd be honored to share the actual PDF artwork with everyone here if they wish to do the same to theirs.
Cheers!
John
Can someone reupload the design ?
Seems like its not on photobucket anymore
KarenColumbo
As soon as this thread reaches 40 pages, I have to build a meat sphere. Fact.
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
rectifierfx
Quote from: KarenColumbo on March 30, 2021, 01:04:05 PM
Nah you gonna build them all :icon_mrgreen: Much more fun. I got kinda addicted to Lovetone stuff. Got the doppelganger already. Wobulator in the bench. Cheese / Source PCB half populated. The only 2 I'm missing is the Sting Ringer and the Flanger without a name
Marcos - Munky
Just commenting anything, to make my contribution for thread to reach 40 pages soon :icon_lol:
KarenColumbo
Quote from: Marcos - Munky on March 30, 2021, 10:14:12 PM
Wait! I didn't mean to ... ah ... damn!
Ooops.  Slipped.  My bad.   :icon_redface: :icon_rolleyes: ;D
Quote from: bluebunny on March 31, 2021, 06:32:19 AM
I, also, need to keep up my bullshit posts quotient.
are we there yet?
