question about making a big muff with an jfet based input and output stage
Started by snow123, May 20, 2022, 03:48:24 PM
jubal81
There was a contest recently for alternatives to build on a muff PCB and I did JFETs all around. Came out great.
https://forum.pedalpcb.com/threads/what-another-contest.10105/page-9
snow123
Quote from: antonis on May 26, 2022, 05:57:32 PM
Quote from: snow123 on May 26, 2022, 05:21:22 PM
Q1 (J201):
D: 2.75
S: 0.00
G: 0.47
Are you sure about Q1 as J201 n-channel JFET..??
yes? i'm using SMD j201s that i soldered onto a through hole adapter board
Quote from: jubal81 on May 26, 2022, 08:55:20 PM
I'm not sure if snow123 would approve the above JFET "anorthodox" (according to his own standards) bias configurations.. :icon_wink:
snow123
Quote from: antonis on May 27, 2022, 05:57:23 AM
tbh i just dialed it in to where it sounded best, and didn't measure until afterwards.
https://i.postimg.cc/tsDrzvSQ/Fuzzduster-SCH.png
As I see that drawing: Q2 Gate has no DC path. If it works it depends on PCB leakage, which is unreliable.
Quote from: PRR on May 27, 2022, 05:33:44 PM
At a first glance, I saw the same thing, Paul..
But it actually does have via R7, C4 short, Sustain wiper and R6..
Quote from: antonis on May 27, 2022, 05:39:23 PM
me counts three.
So, does that make us a crowd..??
P.S.
Finally, snow123 threads DO have "juice"..
jubal81
If it looks weird, it's drawn to be built on a PedalPCB Muff PCB. C4 is a jumper. The treble bypass on the gain control and Q1 bypass cap have to be added extra to the PCB, the orphaned resistors are left empty and the numbering matches the PCB exactly.
snow123
also, using J201s for Q2 and Q3 makes it clean up almost like a fuzz face.
To make the J201s work, I connected the sources of Q2 and Q3 to ground, used 5.1k for R10 and R16, and I lowered R7 and R12 to 2.2k to boost the gain a bit.
Quote from: snow123 on May 28, 2022, 05:06:10 PM
May I notice that the above aren't in compliance with any schematic posted by you (till now, at least..)..??
Phend
  • SUPPORTER+
snow123
snow123
Quote from: antonis on May 28, 2022, 05:30:12 PM
the names are in compliance with the last schem i posted (reply #55), but the values aren't.
Quote from: snow123 on May 29, 2022, 01:05:29 AM
Quote from: Phend on May 28, 2022, 06:03:23 PM
What will this new J Muff be called ?
idk, JFET muff? im bad with naming things lol
Pinchoff Muff would keep everybody guessing.
