Phend
#30001
^ Makes me feel better about my questionable builds, Lol.
    I like Plastic.
  • SUPPORTER+
bluelagoon
Nice Rats Nest  :icon_smile:
it's a bazzfuss, isn't?
Katy who? what footie?
Quote from: duck_arse on July 04, 2024, 10:04:28 AMit's a bazzfuss, isn't?
Yeappp..
(a minimized version..)
Elijah-Baley
Schematic, please. ;D
Quote from: Elijah-Baley on July 05, 2024, 03:39:21 AMSchematic, please. ;D
One Picture, a Thousand Schematics.. :icon_wink:
Focalized
Fuzz Face variant I think was Emanating Fist Electronics Black Acid. Plus a Fjord Odin one knob octave. One of the best sounding silicon fuzzes along with a solid octave fuzz. Together gives lots of texture to play with. Almost perfect fit aside from the input jack touching the bottom plate. So I just flipped the bottom around. Sprayed it with Flex Seal to be safe. Made a scrappy little clip having my Tascam field recorder working. Fender Telesonic into Boss Katana light crunch.
Matthew Sanford
Just sharing my family's protectors during the moonshiner days...
"The only knowledge is knowing you know nothing" - that Sew Crates guy
Controlled Chaos Fx
Willypp
#30009
Haven't posted in ages, not sure what I've kept up with here in terms of builds, so:
A modded Dist+ (BAT41 to ground, LEDs on the gain pot) with clean blend for bass.  Commission build.
A Sansamp bass DI thing
NE-1 on vero with a compressor
Arcadiator
Dual tubescreamer on a Jimilee pcb
Pedalpcb Cliche mini
Pedalpcb Gerkin
A Jimilee Crunchbox pcb with an LPB1 post boost.  Was supposed to be a Jok3rX Sweet Revenge but it was really noisy when boxed up for some reason so I put something else in.
Couple of commissioned Rats using Jimilee's PCBs
All are Tayda UV prints.
for a second, I thought that was Peter Garrett on the Scream Queen. Map of Tasmania?
mozz
NKT OC71's.  Drop in my fuzz face evaluation board, 4.5-5.2v Q2c with stock resistors.  Hope these sound good.
Willypp
Quote from: duck_arse on July 11, 2024, 12:09:39 PMfor a second, I thought that was Peter Garrett on the Scream Queen. Map of Tasmania?
Yep, map of Tassie.  Client wanted this thing on his pedal.  Not sure what the significance of the name though:
Quote from: Willypp on July 14, 2024, 06:25:50 AM
This is a real Tasmanian Devil:
It was also a popular cartoon character.
well. it seems the slang term "the map of tassie" has fallen from current usage, if not favour. I suppose it's because of the latest in hairstyles ......
Quote from: amptramp on July 14, 2024, 08:08:29 AMalso a popular cartoon character.
Good compilation of vintage TD footage:   https://youtu.be/2mKFhNV6mtc?t=210
https://en.wikipedia.org/wiki/Tasmanian_Devil_%28Looney_Tunes%29
And the sad reality-- the critters developed a unique contagious tumor which threatened to wipe them all out. The resolutely anti-social ones may survive.
Focalized
I had this sitting unwired and unpainted for a couple months, was too afraid it wouldn't work. It did and after a cap change to slow down the rate it's pretty close to the demos I've watched. The delay won't self oscillate but its close. These designs are probably very sensitive to values being off here and there. There is ticking like a lot of modulation but it's ok. If it bleeds into the bypass signal turning the rate down it's unnoticeable.
Madbean Gravity Wave (Sea Machine)
Willypp
I'm Australian and currently live in Tassie so I'm well aware of what they represent.  I don't know what the significance of it was to *the client* (also Tasmanian).
Phend
Wombat poop is cube shape. Proof the earth is indeed flat.
  • SUPPORTER+
stallik
Why would evolution do that?
