two layers pcb with UV and spray
Started by Dimitree, June 28, 2011, 04:54:31 PM
Dimitree
Hi guys
has anyone ever tried to make a 2 layers pcb with UV?
I always make my pcb with the UV ways, so I buy pcb with positive layer. Now I would like to do a 2 layer pcb, and I can't find any pcb with 2 positive layers, so I guess I should buy the positive spray (banzai sells it) and use usual pcb material.
Does anyone tried this way? it is easy?
how can I expose to UV a double layer pcb?
defaced
MG Chemicals makes double sided positive board, not sure if it's UV or not.  http://www.mgchemicals.ca/products/600.html
What's the link to the spray you're talking about?
-Mike
Dimitree
thanks but where I can buy those pcb? I'm in europe
this is the spray: http://www.banzaimusic.com/Positiv-20-200ml.html
defaced
Mouser, try this part number: 590-650
-Mike
Dimitree
thanks again, you're really kind but that looks way expensive for a pcb: 9€ + shipping (should be more than 20€).
should be better to buy the spray, I could use it for many pcb.
but I don't know how pratical it is
Gurner
Quote from: Dimitree on June 28, 2011, 05:30:34 PM
re the spray....don't go there - it sucks.
I buy my double sided pre sensitized board from these...
http://www.megauk.com/pcb_laminates.php  (UK based)
Galego
If you order more than 75€ from mouser, the shipping is free.
