Modified Devi Ever Hyperion
Started by mac, October 29, 2014, 07:12:33 PM
mac
This is a simplified Devi Ever Hyperion.
Two diodes instead of the PNP transistor, and one less resistor.
In a recent post PRR got me thinking about how the PNP transistor works.
I saw a Bazz Fuss with another diode going from B to Gnd.
No need for a negative feedback resistor, a silicon diode's tiny leakage can feed the base.
MPSA18 have more gain than those BC549C I used. That's why I increase Q2 collector, to match the leakage.
The bigger the resistor the tighter the sound.
In a Bazz Fuss a darlington does the job better since it needs very tiny currents in its base.
This is what I have on the breadboard right now,
enjoy!
mac
no such packages, but you can install "Quad Cortex", "Helix" or "Kemper" instead.
matmosphere
How does it sound compared to a Hyperion?
mac
bobbysatya
Built and verified! Used 2SC9014D with 630-ish hfe for both transistors. 10k resistor for Q2 gives it right amount of gate. With 100k it squeals. I have built the original hyperion but couldn't get it to work. This one saved me from frustation. Thanks Mac!
Vacuum tube? It's like a light bulb with extra wires, right?
mac
