Ross/Dyna compressor build questions.
Started by alparent, December 08, 2012, 10:21:25 AM
alparent
I'm working on building a compressor with a switch to select between Ross or Dyna values.
(Does the difference between the two justify this?)
I also want to replace the ca3080 with a LM13600.
Any advantages in using both sections of the LM in parallel instead of just one section?
Amy comments on the work in progress is much appreciated.
merlinb
Quote from: alparent on December 08, 2012, 10:21:25 AM
AFAIK, the only difference is one bias resistor (220k or 470k?) If that's all it is, it's definitely not worth the difference.
Not really. But you could make a stereo versions quiet easily!
Might I also suggest my own compressor, the Engineer's Thumb (shameless! :icon_wink:). It does everything a Dyna can do, and much more. And better.
http://valvewizard.co.uk/engineersthumb.html
http://www.diystompboxes.com/smfforum/index.php?topic=97123.0
