EA Tremolo troubleshoot
Started by joshuajamesmacdonald, January 13, 2013, 07:41:54 PM
Hi everyone, I'm trying to get this tremolo pedal up and running and so far no luck.
I power it up, I see a light on the led, and then it immediately fades and does not come back until I unplug the power for a number of minutes before trying again.
No sound comes out of the circuit. (only a loud pop when I connect the battery terminals)
I'm following the schematic from this site:
http://tagboardeffects.blogspot.ca/2012/02/ea-tremolo-modified-rog.html
I am fairly certain I have the pots and inputs/outputs wired correctly. I've looked it over about 20 times!
The transistors I am using are labeled as follows:
Q1 = BS170A, PH69
Q2 = K117, GR2B
Q3 = ST2N, 5088, S6 C
I currently have my transistors set up in the configuration listed in the vero board layout linked above, from what I can gather from datasheets that I can find, I believe these are oriented correctly, but for all I know I have them wrong.
Here are some images of my circuit board
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=48566&g2_serialNumber=1
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=48570&g2_serialNumber=1
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=48573&g2_serialNumber=1
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=48576&g2_serialNumber=1
The schematic says to look for 4.5 - 5 v at Q1 drain, I get between 8.75v and 8.79v depending on my adjustment of the trim pot.
My battery reads 8.8v
With all pots at half value here are all the Transistor voltages I get:
Q1
D: 8.79
G: 3.67
S: 0
Q2
D: 0
G: 0
S: 0
Q3
C: 7.25
B: 6.46
E: 0
Any help would be greatly appreciated.
Thank you!
Josh
Q1 source is not really connected to its resistors.
Q3 is so wrong I can't guess, though incorrect pinout is possible.
000 on Q2 is, for once, normal.
