Stompbox enclosure dimension requests / database
Started by Mac Walker, October 18, 2012, 11:12:56 PM
Mac Walker
Hello fine stompbox aficionados, enthusiasts, addicts, and general lovers of foot operated switching devices for the manipulation of audio signals, creating extensive musical enjoyment!
After having a go at building a batch of aluminum enclosures, I feel inclined to try to take this to the next level...
Here is a list of wedgey-ish, vintagey, hyper stylish super hipster boxes that would be useful to have dimensional information on, all in one place!
I propose that if you have access to any of these models, please to post dimensions for any and all to duplicate, a database if you will.
One rule - use the following format to specify dimensions, to eliminate confusion and adhere to some semblance of a standard -
-  exclude rubber bumber standoffs from the dimensions, measure external metal dimensions only, exluding any height from the floor.
-  can be inches or metric, just specify, use the following format:
HF = height at the front of box, parallel to face, seam to seam (if front face is slightly slanted for example, don't measure perp. to the ground, but parallel to face)
HR = height at rear of the box, same as above
L1, L2, L3, L4 - lengths of each successive top face from front to back.  All measurements parallel to the face, seam to seam.  If L3, L4 don't exist, then they are zero....
W = width.  A few pedals are wider at the rear than the front, if so use WF and WR.
D= depth, bottom face, for reference
Measure twice, write once!!!!
Measure parallel to the face, seam to seam, not perpendicular to the floor!
External dimensions!
Don't worry about angles, they can be worked out in CAD or estimated, unless you have the ability to measure and provide...
This diagram might help to clarify the dimension format request, kind of a unifuzz styled box:
Here's what I would like to have info on, feel free to add to the list.....
Ampeg               Phazzer
Ampeg               Scrambler
Burns                 Buzzaround
Chandler Limited         Germanium boost
Crown                Superfuzz
DeArmond            Square Wave Distortion
Electro Harmonix         Big Muff Pi
Electro Harmonix         Muff Fuzz
Electro Harmonix         Little Big Muff
Electro Harmonix          Memory man (special case - maybe HF1, HF2, HR1 HR2)
Fender                 Blender
Fender                Starcaster Distortion
Faylon                F72 Fuzz Machine
FoxRox                 Octron 2
FoxRox                Hot Silicon
Fulltone                     Full-Drive2 / Bass-Drive
Gretsch                      Controfuzz
Guyatone                       Fuzz
HeathKit                      TA-28 Fuzz
Hoffner                         Buzz Tone
Ibanez                    Stereo Box
Ibanez                   Standard Fuzz
Interfax                        Harmonic Percolator
JHS                            Zonk Machine II (steel, sloped back)
JMI / Sola                  Tonebender MK I
Knight Allied                 Fuzz
Maestro                   Fuzz Tone (small)
Maestro                   Fuzz Tone (large)
Maestro                   Bass Brassmaster
Moog                   moogerfooger(exclude wood sides, sheet metal only)
Mosrite                   Fuzz Rite
Mutronics                        Mutron III
PAX                            Octave Box
Roger Mayer                 Octavia
Rosac Electronics              NU-FUZZ
Shin Ei                    FY-2
Shin Ei                    Uni-Fuzz
Thunder Electronic Co.      Royal Fuzz Box
UMI                            Buzz Tone and Volume Expander
Wem-Rush                 Pep Box
Yeah!!!  Thanks team!!!
Keppy
Ampeg Scrambler Reissue, all units in inches
HF1: .9
HF2: .1
HR: 1.25
L1: .05
L2: 5.45 (curved!)
L3: 1.45
W: 4.5
D: 6.75
Megatron
These MKI dimensions were posted on the DAM forum.
John Lyons
Nothing to add at the moment except.
Go Mac Go!!
Basic Audio Pedals
www.basicaudio.net/
Perrow
Shin Ei - Super Fuzz
Measurements of the recess (indent?) are from edge to where the "next" flat surface starts.
Recesses for switch and jacks are 3mm deep.
Anything unclear or unmeasured, just ask.
Perrow
Forgot to add a gutshot.
For total authenticity add a sticker on the bottom side of the bottom plate  ;D
No wonder I keep frying my batteries.
Mac Walker
Cool, thanks for sharing!
I hope my enthusiasm hasn't scared everyone away, ha ha.....
Early nineties (black) russian big muff:
HF=35 mm
HR=53 mm
W= 119 mm
D=166 mm
Mac Walker
