dd-5 elephant blend mod
Started by rice37, February 14, 2013, 03:45:56 PM
rice37
THIS IS THE MOD I NEED TO DO!!!!!
http://www.youtube.com/watch?v=NT6gxKP9soY
of course its in another language! Some one has GOT  to be able to show/tell how to do this mod. Its obviously way cooler, than the kill mod, or just removing the C9.
Please for all that is holly someone say they know how to do this!!
Paul Marossy
rice37
Isnt it? Someone has got to know how to do this
I think it talks about rewiring the level pot into a mix pot, so at one extreme you get just the dry signal and at the other extreme you get just the wet. If that's what it is then it shouldn't be too hard to figure out.
rice37
Right so how would I do that? Is it as simple as jumping a couple wires on the pot
Not sure exactly how you'd do it, making the knob into a blend looks fairly easy but I'm not sure how it keeps the bypass signal. I might be able to figure it out with a bit of information. In the video it's using the Panning out, what happens if you use just that output with the stock pedal, do you get the dry signal in bypass and just the wet signal when the delay is on?
