U426 dual jfet transistor
Started by Jussi, March 08, 2013, 10:07:05 AM
Jussi
I got four of these transistors. I'd really like to hear these things but I don't know how to set them up. Some of the specs looked a little same than with J201. Is it possible to make a booster or two stage distortion pedal with one of these if using only 9 volts from a battery?
Datasheet: http://www.datasheetarchive.com/dataframe.php?file=Book-42094.pdf&dir=Databooks-4&part=U426#
If I'm using 9 volts, how big resistors or trimpots I should put for drain and source pins to even get some sound? What should be the voltage at the pins? And do I need big capacitors (like 50 µF) from source pins to ground?
EDIT: not sure if these are germanium but when i googled these i found somebody selling them as germanium transistors at ebay
kingswayguitar
can i ask where you bought them? i wouldn't mind trying a few. the datasheet doesn't indicate, but i wonder how closely they're matched. the datasheet also doesn't say they're germanium??
to answer your question....i'd just look up jfet boost or common source amplifier. lots of discussion at this forum about the subject. not too tough. your battery is drawn backwards by the way. and you don't need such a big capacitor, anything over about 0.1 uF starts to help. 50 is fine though.
oh yeah, and notice your jfets are directly (dc) coupled because there's no capacitor between them. this is possible but involves differences from transistors that are decoupled with a capacitor.
darron
Huh? A dual germanium jfet? Really? :D
You could make a mu-amp stage...
Schematic at the bottom:
http://www.geofex.com/Article_Folders/modmuamp/modmuamp.htm
They were made by Siliconix.
Jussi never said "germanium".
Bottom of first page, "MATCH".
darron
What the heck. Thought I saw it in the topic title when it was posted.  Then again was 6:30 am or something. Thays ehy it dodnt make sense to me. Dual matched jfet a in a package would be so useful
It's "Kurns"
No it's not.
Disregard.
kingswayguitar
Quote from: PRR on March 08, 2013, 06:39:26 PM
thanks
MATCH is written vertically so I missed it  :icon_redface:
and i see one listing on all of ebay C $9.22 for 2
that seller does claim they're germanium
hmmmmm
J0K3RX
From FET Design Catalogue 1979... Bet you won't find many of these too often!
