oscillation in Ne5532 simple preamp
Started by DiggyFresh, March 19, 2013, 06:22:56 PM
DiggyFresh
Hi folks!
i'm toying with a very simple pre-amp circuit with a Ne5532,  the circuit can be found here:
http://schematicdiagrams.net/images/0/electret-microphone-pre-amp.jpg
from this page: http://schematicdiagrams.net/small-electret-microphone-pre-amplifier.html
I use it to drive a line input. i replaced R5(100k) with a 10k in series with a 250k pot for gain control (in negative feedback) (as described in article)
the issue i'm having is when i turn the gain pot a little from minimum, it adds a pitched tone that varies in frequency with the gain control pot.
I have very limited knowledge in opamp design, i guess this is due to oscillation (?)
Any way i could improve stability ??   i dont need frequencies above 10k-15k, maybe i could add a simple filter?
It showed up during testing with a bunch of aligator clips tho, will it be more stable once wired and shielded in the box?
or maybe try with a tl072?
any help appreciated , thanks
John
It's almost certainly an issue with one of:
- power supply decoupling; there should be a 10uF and a 0.1uF *ceramic* cap as near the +V and -V pins as you can get them, both electrically and physically.
- a wiring issue, where the wires don't go exactly where you think they do
- a soldering or bad contacts issue.
DiggyFresh
Thanks R.G,
I cured the problem swapping the ne5532 with a tl072, the "oscillation" went away and the gain pot now functions normally.
i guess maybe because of the higher bandwidth of the ne5532,  my 9volts battery is already decoupled like you said with 100uf and 0.1uf but not ceramic.
what i don't get is i used a circuit initialy using the ne5532....
Is there a "cure"  to be able to use the ne5532?   i wanted to use it because of the low noise, but may not make a difference in my application...
Something like an rc network somewhere to get rid of the higher frequency or something?
thanks!
Lurco
{as Lurco says} R7 *really* needs to be bypassed to ground with several uFd cap.
It's high-gain (more with your mod). If output is anywhere near input, it is sure to howl.
The basic topology is non-optimal. Non-inverting is quieter. For 2-pin electret bandwidths, one '5532 stage can do your gain of 250 (if you really need that much).
(Let me know if that image does not show.... trying something new.)
DiggyFresh
Thanks alot guys!  that's the kind of info i needed.  I will try to add a big cap across R7 to see if it helps!
@PRR  thanks! I wish i had found a schematic like yours first, i will try it also.  When you say for "electret bandwidth" , what kind of bandwidth do you mean?
  i found the first circuit online but i'm not using it for an electret microphone. I was looking for a simple, lowest possible noise pre-amp to replace
  a lm386 output stage in a toy voice changer to get a better, more linear line level output. (a black blob chip, wich i don't know the output impedance..).  My first circuit works, and is an improvement but if there's a better circuit for my application i will try it.  The  voice changer chip is a pretty Lo-fi effect and must have a small bandwidth but i would like to have a circuit wich can get the most out of it.
any ideas realy apreciated, i'm brand new to these small opamp preamp circuit.
