Can someone give me an Amp (i mean the circuit)
Started by Rock_on, March 03, 2013, 03:36:57 AM
Rock_on
so you guys already know what kind of music i play right? for those of you who are not you can just look for my other thread.
hmm what i have here is 1 100W speaker and a 400W speaker from my old amp (which is already broken, cant be repaired anymore unless make a new circuit)..
that's all. thanks :DD
Ronan
...I turned the volume down...
Rock_on
bump...
can someone pls?? if possible i want two channel
clean and dirty.. thanks :DD
Mustachio
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Rock_on
i want a jcm2000 similar.. cant build the jcm2000 too hard for me.. and expensive..
any clone available?? what about orange amp??
geertjacobs
#6
What do you want?
- a solid-state amp /  tube amp?
- low power (5watts) - enough power (15 watts - 30 watts) - more than enough power (50 watts) - too much power (100 Watts)?
Solid state: You can take a preamp from  http://www.runoffgroove.com/articles.html  and put a poweramp after http://www.generalguitargadgets.com/pdf/ggg_lm3886_amp.pdf.
Tubes: you can build kits from weber or http://ceriatone.com/ or puzzle your own parts together.
Buying second-hand is in most cases cheaper than building:
For tube amps: you could buy a second-hand Epiphone Valve Junior and start experimenting.
http://duhvoodooman.com/vjr/vjr_mods.htm
But if you like to build, go build!
Rock_on
#7
50W.. solid state
is that enough for a bedroom player?
geertjacobs
#8
5 watts is probably already too much for a bedroom player...
But there is a nice SS amp project called the Tiny Giant.
It's 20 watts and uses a laptop power supply so you dont' have to work with mains voltages yourself.
Build some nice FET preamps from runoffgroove to go in front et voila!
Somicide
Quote from: geertjacobs on March 16, 2013, 12:09:33 PM
or J0k3r's...
Peace 'n Love
Rock_on
Quote from: Somicide on March 17, 2013, 03:20:09 AM
or J0k3r's...
haha that's on my mind.. thanks guys!!
btw how loud is 20W?? any sound clips from tiny giant amp?
jogina111
#11
Using your speakers, 20watts would be enough to play on rehearsals, on bars and a little loud if your'e playing on a church.  I suggest you build a ruby amp from runoffgroove. Its very suitable for your kind of music plus it has a gain control to help you with heavier genres. Very good for bedroom players and very easy to build..
Rock_on
#12
is this the layout for pcb?
i'll just turn it to black and white and mirror it right??
cant do it..
please give it to me..
azrael
No, it's a double sided layout. Just buy it, it's very cheap, and it's a great project. Support the guy who developed it.
Rock_on
dont have the money for shipping. and i dont have credit/debit cards
jogina111
There's a PDF file which you can download at taylor's site and it contains the schematic for the tiny giant.You can try building it based on that schematic.
Rock_on
Thank you for that!! :DD
btw i thought it has 2 channels according to the taulor's poll? But what happen??
jogina111
Its a single channel amp for simplicity's sake.. If you want 2 channels, you would want 2 power amp sections for left and right channels.
Rock_on
Quote from: jogina111 on March 21, 2013, 06:46:56 AM
No i mean clean and dirty???
azrael
It's a simple simple SIMPLE amp. If you want distortion, go build a distortion pedal.
It's meant to be a clean transparent amp, not necessarily a guitar amp.
