Npn boost problems
Started by VolksWilliam, March 24, 2013, 10:07:25 AM
VolksWilliam
Ok. Just finished the npn boost. Here's the problem. I've got true bypass signal. When on I've got led but only very low volume.
I don't have a way to take a photo right now but I took some measurements and maybe someone can suggest a fix for me.
All volts are as should be besides the transistor.
E 2.74
B 2.89
C 3.54
Triple checked the schematic but I've already had to fix a few things. So where do I start now?
Do you have a link to the other information requested in "Debugging: what to do when it doesn't work"?
