Vox Clyde McCoy wah DIY build report help needed!
Started by Leepyringa, April 06, 2013, 04:37:49 AM
Leepyringa
Guys! I made vox clyde wah using fuzzcentral schematic with few minor alterations (some resistor values) and that what i came up with :
Transistors are CDIL BC109B with hfe ~400 both
I used whipple inductor , and ICAR pot from dandyjob.com and it sounds freakin' cool!! I really didn't expect this to sound so smooth and nice!
BUT! I have some little noise that comes along with signal and it sounds scratchy when I rock my pedal up and down ... It's pretty subtle but i want to get rid of it
I read R.G.'s article about wah  on geofex (btw great article , thank you so much!) but i still cannot figure out which resistor to change ... tried to change resistors that go from 9v+ to transistor collectors but that didn't help at all...
Please guys , I need your help!
Cheers!
Mich P
Could be the pot clean it, or change it !
Mich P.
Leepyringa
Thanks , Mich! But it's not the pot ... subtle noise always present but it's only noticeable when pedal is toe down cause of frequency change...
Pot doesn't make noise itself
I think I need to change some resistors but i cannot figure out where to start :-\
joegagan
#3
the way pots are made, the R range goes wonky at the extreme ends.
have you tried changing where the gear rides?
also, condomback pots (often) go scratchy very fast, regardless of brand.
Leepyringa
Damn ... I checked everything once again and listened more carefully ... I think that pot is a noisy guy , will try to clean it somehow
Thanks everyone!
