Charge pump voltage offset issue
Started by trixdropd, April 15, 2013, 03:21:32 PM
trixdropd
I built a chargepump circuit for bipolar power with a tc1044 based off the hume free a/b/y at ggg. For some reason, the - out is half a volt lower than the input voltage. This seems to be causing distortion on the inverted outputs on my tl072's it powers.
I removed the chip and breadboarded it and the power is fine. In circuit though I can't get the issue to go away. What could I be doing wrong?
http://www.geofex.com/FX_images/humfree2.gif
Govmnt_Lacky
trixdropd
I haven't solved this, but I'm pretty sure it's the opamp rather than the voltage. Side b is very low and distorted, but I have multiple tl072's in parallel and only 1 has an issue. I swapped it out but the problem is the same. Gonna look for a solder bridge.
trixdropd
It was a micro solder bridge on the output of the inverting side. Sounds good now! I guess the 1/2 volt drop between +9v and and -9v don't matter, even though on the breadboard there wasn't quite a drop.
That's the way it works. It is a voltage-doubler, but not perfect. There's always loss. Diodes, or in this case probably FETs (internal).
No. Chip opamps work fine with unbalanced voltages. You only need "enough" to cover your signal (plus losses). -8.5V is more than enough to cover guitar swings.
Yeah, solder-bridges suck tone real bad. I hate when that happens.
